Internal Error occured during: "Launching New_configuration". No Target with ID 64 in the system
I'm using the vivado block design integrator to connect a custom IP(memory controller) to the Zynq PS. When I try to change the linker to place the code in PL DDR, it gives me the following error:
ERROR : Unexpected error while launching program.
java.lang.RuntimeException: Failed to download ELF file
Unknown Error Occured
Section, 0x40000000-0x4000ada3 Not Accessible from Processor I-Side Interface
at com.xilinx.sdk.targetmanager.internal.TM.downloadELF(TM.java:670)
at com.xilinx.sdk.debug.core.internal.AppRunner.run(AppRunner.java:129)
at com.xilinx.sdk.debug.core.XilinxAppLaunchConfigurationDelegate.runApplication(XilinxAppLaunchConfigurationDelegate.java:609)
at com.xilinx.sdk.debug.core.XilinxAppLaunchConfigurationDelegate.launch(XilinxAppLaunchConfigurationDelegate.java:296)
at com.xilinx.sdk.debug.ui.XilinxAppLaunchDelegateWrapper.launch(XilinxAppLaunchDelegateWrapper.java:31)
I tried to change the size of stack and heap as per other solutions but there was no change. Please provide help with this issue.
I'm using Vivado 2015.2 with Zynq ZC706.
Nitin.
