Interrupts from a custom IP
Hi there :-)
I have connected an external peripheral to microblaze through PLB bus.
I have a signal from the peripheral which is supposed to act as interrupt.
Should I still use XPS INTC?
If not,could you please let me know how to do so?
Thank you and regards,
anand :-)
htsvn
If you have multiple interrupts coming from different peripherals you need a Interrupt controller.
if you have a single interrupt coming from a single peripheral you need not have a interrupt controller.
Check page number 24 of http://www.xilinx.com/support/documentation/application_notes/xapp778.pdf
Thnx
berufspenner
I don't have a clue about the microblaze but I think it might be the same as with the ppc. So if you've just one interrupt source, you don't need an interrupt controller. Otherwise you need the interrupt controller to manage several interrupt sources and set priorities, etc.
htsvn
Thnx
Hi 'hem_8030' :-)
I found the document you suggested pretty useful :-)
Thank you :-)
