mojc_mos2
Interrupts in the FREERTOS
How can I use interrupts in the SDK freertos? do you have any example?
Best Regurds
hbucher
@mojc_mos2
See if this helps
http://www.freertos.org/Free-RTOS-for-Xilinx-MicroBlaze-on-Spartan-6-FPGA.html#implementing_an_ISR
mojc_mos2
can i use sdk interrupt commands in the freertos ? there are easy example to get interrupt from FPGA for freertos?
Best Regards
