11-07-2016 11:06 AM
On Vivado/SDK 15.2, on a project I've been developing with for several months with no problems I was fiddling with the parameters of the AXI Interrupt controller and after a successful Vivado build, when the BSP regenerated, xparameters.h was missing the interrupt definitions:
#define XPAR_INTC_SINGLE_BASEADDR 0x41200000
#define XPAR_INTC_SINGLE_HIGHADDR 0x4120FFFF
#define XPAR_INTC_SINGLE_DEVICE_ID XPAR_MICROBLAZE_0_AXI_INTC_DEVICE_ID
#define XPAR_MICROBLAZE_0_AXI_INTC_TYPE 0
#define XPAR_UART_COMM_IP2INTC_IRPT_MASK 0X000001
---- xparameters identical to here, new xparameters missing items below which always had been there------------------------
#define XPAR_MICROBLAZE_0_AXI_INTC_UART_COMM_IP2INTC_IRPT_INTR 0
#define XPAR_NPILCD_0_LCD_IRPT_MASK 0X000002
#define XPAR_MICROBLAZE_0_AXI_INTC_NPILCD_0_LCD_IRPT_INTR 1
#define XPAR_AXI_ETHERNET_0_ETH_BUF_INTERRUPT_MASK 0X000004
#define XPAR_MICROBLAZE_0_AXI_INTC_AXI_ETHERNET_0_ETH_BUF_INTERRUPT_INTR 2
#define XPAR_FPANEL_1_FP_IRPT_MASK 0X000008
#define XPAR_MICROBLAZE_0_AXI_INTC_FPANEL_1_FP_IRPT_INTR 3
#define XPAR_RTC_TMP_I2C_IIC2INTC_IRPT_MASK 0X000010
#define XPAR_MICROBLAZE_0_AXI_INTC_RTC_TMP_I2C_IIC2INTC_IRPT_INTR 4
etc.... for all interrupts
Since then I've restored my previous AXI_INTC configuration and rebuilt the vivado project, deleted the bsp and rebuilt it, deleted the hardware definition and rebuilt it, deleted my entire Vivado project and restored it from a copy that had never been played with and no matter what I do, xparameters.h is missing the interrupt definitions. I can't even figure out where this problem lives. It's not in the .hdf file, since I'm using a clean one that yields a perfect xparameters.h on another engineers system.
Does anyone have any ideas how to correct this? I'm losing precious time fighting the tools.
RANT ON---
Since switching to Vivado from good old ISE 14.3 I spend more time fighting tools and way less time engineering product.
Had to say it.
RANT OFF---
thanks in advance.
11-07-2016 08:17 PM
11-08-2016 06:22 AM
11-09-2016 09:27 AM - edited 11-09-2016 09:28 AM
Can you try this configuration in INTC IP?
Praveen
