jbigo12
Invalid command name "configparams"
Hello everyone,
I am currently working with a Xilinx-Zynq XC7Z010-1CLG400C board and trying to load the hardware configuration via XMD from SDK 2014.3 (I am forced to work with this older version). The issue arises while running the method ps7_post_config.
I will try to describe my steps:
- Create hardware configuration with Vivado 2018.3
- Open XMD:
   XMD% connect arm hw
   XMD% source ../file.tcl
   XMD% ps7_init    (I had to remove all "force" words from the tcl, as discussed here)
   XMD% ps7_post_config
    invalid command name "configparams"
Did anybody face the same or a similar issue? I attach the .tcl file, in case of interest.
Many thanks.
sadanan
HI @jbigo12,
You can delete lines 764, 765, 779. configparams command is not supported by XMD
sadanan
HI @jbigo12,
jbigo12
Thank you @sadanan. I removed the lines and everything worked out.
