Is msgsnd thread safe in Xilkernel?
Is msgsnd thread safe in xilkernel?  Put another way, if two threads try to call msgsnd at the same time, will one be blocked until the other one is done passing the data to the queue? I'm not concerned about what happens if the queue is full, just what happens if two threads try to call it at the same time.  Thanks
Steve
Bump.
