davidsummers
Is there a way to specify a software repository from a TCL script?
I have a TCL script to build my Vitis workspace and embedded Zynq app from source.    There is one manual step left in my process.  From the GUI I have to do the following:  "Window -> Preferences -> Xilinx -> Software Repositories"  and enter the name of a local repository.
Is there a way to automate this step with the TCL script?
marcb
Hi @davidsummers
I would try:
repo -set <repository_directory>
repo -scan
From XSCT, the "help repo" will provide all available arguments.
marcb
Hi @davidsummers
I would try:
repo -scan
davidsummers
Yes, that worked.  Thank you!
