Visitor wwang_el
Is ultrascale+ MPSoc support other debug tool such as IAR Jlink?
the ARM DAP is unavailable by Power on reset.
we have use jtagload to enable ARM DAP, but it can't work
the following information is generated by using IAR Jlink.:
Mon Jul 16, 2018 16:56:13: JTAG chain detection found 2 devices:
Mon Jul 16, 2018 16:56:13:  #0 Id: 0x5BA00477, IRLen: 04, CoreSight JTAG-DP
Mon Jul 16, 2018 16:56:13:  #1 Id: 0x24738093, IRLen: 12, Unknown device
Mon Jul 16, 2018 16:56:13: Scanning AP map to find all available APs
Mon Jul 16, 2018 16:56:13: AP[3]: Stopped AP scan as end of AP map has been reached
Mon Jul 16, 2018 16:56:13: AP[0]: AXI-AP (IDR: 0x34770004)
Mon Jul 16, 2018 16:56:13: AP[1]: APB-AP (IDR: 0x44770002)
Mon Jul 16, 2018 16:56:13: AP[2]: JTAG-AP (IDR: 0x24760010)
Mon Jul 16, 2018 16:56:13: Iterating through AP map to find AHB-AP to use
Mon Jul 16, 2018 16:56:13: AP[0]: Skipped. Not an APB-AP
Mon Jul 16, 2018 16:56:13: AP[1]: APB-AP found
Mon Jul 16, 2018 16:56:13: ROMTbl[0][0]: CompAddr: 80100000 CID: B105F00D, PID:04-001BB101 TSG
Mon Jul 16, 2018 16:56:13: ROMTbl[0][1]: CompAddr: 80110000 CID: B105900D, PID:04-002BB908 CSTF
Mon Jul 16, 2018 16:56:13: ROMTbl[0][2]: CompAddr: 80120000 CID: B105900D, PID:04-002BB908 CSTF
Mon Jul 16, 2018 16:56:13: ROMTbl[0][3]: CompAddr: 80130000 CID: B105900D, PID:04-002BB908 CSTF
Mon Jul 16, 2018 16:56:13: ROMTbl[0][4]: CompAddr: 80140000 CID: B105900D, PID:04-001BB961 TMC
Mon Jul 16, 2018 16:56:13: ROMTbl[0][5]: CompAddr: 80150000 CID: B105900D, PID:04-001BB961 TMC
Mon Jul 16, 2018 16:56:13: ROMTbl[0][6]: CompAddr: 80160000 CID: B105900D, PID:04-001BB909 ATBR
Mon Jul 16, 2018 16:56:13: ROMTbl[0][7]: CompAddr: 80170000 CID: B105900D, PID:04-001BB961 TMC
Mon Jul 16, 2018 16:56:13: ROMTbl[0][8]: CompAddr: 80180000 CID: B105900D, PID:04-004BB912 TPIU
Mon Jul 16, 2018 16:56:13: ROMTbl[0][9]: CompAddr: 80190000 CID: B105900D, PID:04-004BB906 CTI
Mon Jul 16, 2018 16:56:13: ROMTbl[0][10]: CompAddr: 801A0000 CID: B105900D, PID:04-004BB906 CTI
Mon Jul 16, 2018 16:56:13: ROMTbl[0][11]: CompAddr: 801B0000 CID: B105900D, PID:04-004BB906 CTI
Mon Jul 16, 2018 16:56:13: ROMTbl[0][12]: CompAddr: 801C0000 CID: B105900D, PID:04-001BB963 STM-500
Mon Jul 16, 2018 16:56:13: ROMTbl[0][13]: CompAddr: 801D0000 CID: B105900D, PID:01-00093F21 ???
Mon Jul 16, 2018 16:56:13: ROMTbl[0][14]: CompAddr: 801E0000 CID: B105900D, PID:01-00093A21 ???
Mon Jul 16, 2018 16:56:13: ROMTbl[0][15]: CompAddr: 801F0000 CID: B105900D, PID:01-00093A21 ???
Mon Jul 16, 2018 16:56:13: ROMTbl[0][16]: CompAddr: 803E0000 CID: 00000000, PID:00-00000000 ???
Mon Jul 16, 2018 16:56:13: TotalIRLen = 16, IRPrint = 0x000511
Mon Jul 16, 2018 16:56:13:  #0 Id: 0x00000001, IRLen: ?, Unknown device
Mon Jul 16, 2018 16:56:13:  #1 Id: 0x24738093, IRLen: ?, Unknown device
Mon Jul 16, 2018 17:12:07: IAR Embedded Workbench 8.22.2 (C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0_3\arm\bin\armproc.dll)
I found out that the address at ROMTbl[0][15] and ROMTbl[0][16]  is forbidden to visit when using vivado to debug, but why it is in ROMtbl ?
回复: Is ultrascale+ MPSoc support other debug tool such as IAR Jlink?
Hi @wwang_el,
Unfortunately for you there is no support for IAR Jlink on Xilinx SDK System Debugger.
Ibai
Ibai
Visitor wwang_el
correct: ROMTbl[0][14] and ROMTbl[0][15]  is forbidden to visit .
that means the memory address (0xfe800000  + 0x1e0000 )and (0xfe800000+0x1f0000) is forbidden to visit.
I think mybe that is why the jlink can't continue to read  ROMTbl[0][16] which  is R5 Rom table.
Visitor wwang_el
Is there any solution for this kind of issue?
Hi @wwang_el,
Ibai
Ibai
