peterjohn
Issue in launching Petalinux
I have installed Petalinux 2018.3 in Ubuntu 18.04 but I am not able to source the settings.sh file.
How to fix the problem ?
peter@peter:~$ source ~/opt/xilinx/Petalinux/settings.sh
PetaLinux environment set to '/home/peter/opt/xilinx/Petalinux'
WARNING: /bin/sh is not bash!
bash is PetaLinux recommended shell. Please set your default shell to bash.
WARNING: This is not a supported OS
INFO: Checking free disk space
INFO: Checking installed tools
environment: line 311: ((: 10#15~1 > 10#3: syntax error in expression (error token is "~1 > 10#3")
environment: line 315: ((: 10#15~1 < 10#3: syntax error in expression (error token is "~1 < 10#3")
INFO: Checking installed development libraries
INFO: Checking network and other services
WARNING: No tftp server found - please refer to "PetaLinux SDK Installation Guide" for its impact and solution
patocarr
Hi @peterjohn
  You may want to change to bash by using this command
sudo dpkg-reconfigure dash
  After that, you may need to restart your login session before retrying with Petalinux.
-Pat
Give kudos if helpful. Accept as solution if it solves your problem.
https://tuxengineering.com/blog
watari
Hi @peterjohn
Would you change default shell from dash to bash ?
This url is direct answer. But it's one of the solution.
Would you try it ?
https://www.xilinx.com/support/answers/60088.html
Best regards,
peterjohn
@watari , I don't have Vivado and SDK. I just have Petalinux 2018.3 in Ubuntu 18.04 in virtual machine.
watari
Hi @peterjohn
Would you change default shell from dash to bash on your Ubuntu ?
$ sudo rm /bin/sh
$ sudo ln -s /bin/bash /bin/sh
This solution is same as my previous URL.
Would you try it ?
Best regards,
peterjohn
I just run both commands.
peter@peter:~$ sudo rm /bin/sh
[sudo] password for peter:
peter@peter:~$ sudo ln -s /bin/bash /bin/sh
I still have environment error. I am also wondering about this warning "This is not a supported OS".
patocarr
Hi @peterjohn
-Pat
