Issue with Xilinx SDK eclipse jlink debugging plugin
I have the Xilinx SDK eclipse 2017.3 version.
I want to debug my code using the JLINK debugger. I am not able to find the right GNU ARM C/C++ J-link debugging PLUGIN. I tried several plugins from https://gnu-mcu-eclipse.github.io/developer/releases/ and http://gnuarmeclipse.sourceforge.net/updates/ It is unable to install the plugins with the following errors:
Cannot complete the install because of a conflicting dependency.
  Software being installed: GNU ARM C/C++ J-Link Debugging 4.1.4.201704251808 (ilg.gnuarmeclipse.debug.gdbjtag.jlink.feature.group 4.1.4.201704251808)
  Software currently installed: Xilinx SDK 1.0.0.201710050240 (com.xilinx.sdk.product.plugin 1.0.0.201710050240)
  Only one of the following can be installed at once:
    GNU ARM C/C++ Debugging Core 1.2.1.201704251808 (ilg.gnuarmeclipse.debug.core 1.2.1.201704251808)
    GNU ARM C/C++ Debugging Core 1.2.1.201602091039 (ilg.gnuarmeclipse.debug.core 1.2.1.201602091039)
    GNU ARM C/C++ Debugging Core 1.2.1.201602262119 (ilg.gnuarmeclipse.debug.core 1.2.1.201602262119)
  Cannot satisfy dependency:
    From: Xilinx SDK 1.0.0.201710050238 (com.xilinx.sdk.feature.feature.group 1.0.0.201710050238)
    To: ilg.gnuarmeclipse.debug.core [1.2.1.201602262119]
    From: Xilinx SDK 1.0.0.201710050240 (com.xilinx.sdk.product.plugin 1.0.0.201710050240)
    To: com.xilinx.sdk.feature.feature.group [1.0.0.201710050238]
    From: GNU ARM C/C++ J-Link Debugging 4.1.4.201704251808 (ilg.gnuarmeclipse.debug.gdbjtag.jlink.feature.group 4.1.4.201704251808)
    To: ilg.gnuarmeclipse.debug.core [1.2.1.201704251808]
Any help is appreciated.
ibaie
Hi @divyavkalkotwar,
Unfortunately Xilinx SDK does not support third party debuggers, so to be honest I don't even know if this is mean to work with an external plugin.
Let see if somebody else has experience with JLINK and Xilinx SDK.
Ibai
Ibai
