lauziepi
JTAG boundary scan from a FPGA
my plan is to use four GPIO pins of a FPGA to create a JTAG chain with another FPGA. On the first FPGA I have a microblaze, and I'd like to be able to perform a boundary scan to read the second FPGA's id. What would be the easiest way to achieve this? I'm pretty sure there should be ab open-source JTAG API somewhere but I could not find anything.
gszakacs
Professor
Professor
If you want to use the MicroBlaze to bit-bang the JTAG interface over GPIO, you probably want to look at XAPP058.
Document:
http://www.xilinx.com/support/documentation/application_notes/xapp058.pdf
Design files:
http://www.xilinx.com/support/documentation/application_notes/xapp058.zip
-- Gabor
austin
l,
Search for;
jtag tap controller verilog or vhdl code.
They are out there.
Just need to know what the name ofthe function is you need (JTAG test access port - tap-  controller).
Austin Lesea
Principal Engineer
Xilinx San Jose
gszakacs
Professor
Professor
Document:
Design files:
-- Gabor
