maps-mpls
Mentor
Mentor
Just sharing how to create a map file for uB in standalone/baremetal application
To create a map file for a microblaze application, this is the syntax:
-Wl,-M=c:/delme/test.map
Note to Xilinx:  Could you update UG1043 to be more complete...the section highlighted in yellow could use more detail.  Searching on the forums turns up a variety of answers, and they are not necessarily consistent with the latest tools.  It is possible it is a different option for arm--I didn't check.  If so, please specify the map file creation option for arm as well.  Maybe it is already documented somewhere in DocNav but I could not find it in a reasonable amount of time.
 Or provide links on this thread to the proper answer records.
*** Destination: Rapid design and development cycles *** Unappreciated answers get deleted, unappreciative OPs get put on ignored list ***
ibaie
Hi @maps-mpls,
Thanks for your contribution in the forum, it's being great to see people participating in the Forum and contributing in the overall knowledge of Xilinx users.
Kudos for you!
Ibai
Ibai
maps-mpls
Mentor
Mentor
Thanks for the kudos.  It's fun.
praveen@veoneer
Hi Voyager,
I am getting permission error while generating map file.
I followed the same command and tried to creat map but but encountered with permission denined error.
Currently i am using Vivado 2018.2 in windows 10, 64 bit processor.
I have also tried in different paths just to confirm, but still i am getting permission denied error.
Please let me know how to avoid this error. i am getting this error only if i tried to create map file.
PraveenKumar.
