KINTEX KC705:LWIP-Ethernetlite:recv_callback Function
    Kintex KC705 receiving the 32-bit counter data from DAQ board and passing to PC through AXI-Ethernetlite, where data should be read in Hercules or Putty
Block diagram
Can anyone Please tell me how to receive the 32-bit Counter data in ECHO file. How to modify the code to receive the 32-bit counter data.
I did some included Conversion Function for Hercercules. But It is not working Properly
#include <stdio.h>
#include <string.h>
#include <math.h>
#include <stdlib.h>
#include "ar_rx.h"
#include "lwip/err.h"
#include "lwip/tcp.h"
#if defined (__arm__) || defined (__aarch64__)
#include "xil_printf.h"
#endif
char buf[32] = {0};
extern u32 DestinationBuffer[5];
int transfer_data() {
	return 0;
char *itoa(int val, int base){
 int i = 30;
for(; val && i ; --i, val /= base)
buf[i] = "0123456789abcdef"[val % base];
return &buf[i+1];
void print_app_header()
	xil_printf("\n\r\n\r-----lwIP TCP echo server ------\n\r");
	xil_printf("TCP packets sent to port 6001 will be echoed back\n\r");
err_t recv_callback(void *arg, struct tcp_pcb *tpcb,
                               struct pbuf *p, err_t err)
	int i,Status;
	Status=aurora_rx_main();
	//xil_printf("%d",DestinationBuffer);
	//u32 rx_fifo_data;
	for(i=0;i<5;i++)
		xil_printf("%d,",DestinationBuffer[i]);
	xil_printf("\n");
	    int base=10;
	    char *result={0};
	    char *result1={0};
	    char *result2={0};
	    char *result3={0};
	    char *result4={0};
	    result = itoa(DestinationBuffer[0],base);
	    result1 = itoa(DestinationBuffer[1],base);
	    result2 = itoa(DestinationBuffer[2],base);
	    result3 = itoa(DestinationBuffer[3],base);
	    result4 = itoa(DestinationBuffer[4],base);
	/* do not read the packet if we are not in ESTABLISHED state */
	if (!p) {
		tcp_close(tpcb);
		tcp_recv(tpcb, NULL);
		return ERR_OK;
	/* indicate that the packet has been received */
	tcp_recved(tpcb, p->len);
	/* echo back the payload */
	/* in this case, we assume that the payload is < TCP_SND_BUF */
	if (tcp_sndbuf(tpcb) > p->len) {
		//err = tcp_write(tpcb, p->payload, p->len, 1);
		//xil_printf("%s %s",result[0],result[1]);
		err = tcp_write(tpcb,result,2,1);
		err = tcp_write(tpcb,result1,8,1);
		err = tcp_write(tpcb,result2,6,1);
		err = tcp_write(tpcb,result3,2,1);
		err = tcp_write(tpcb,result4,2,1);
	//aurora_rx_main();
	//xil_printf("%c",ascii[0]);
	} else
		xil_printf("no space in tcp_sndbuf\n\r");
	/* free the received pbuf */
	pbuf_free(p);
	return ERR_OK;
err_t accept_callback(void *arg, struct tcp_pcb *newpcb, err_t err)
	static int connection = 1;
	/* set the receive callback for this connection */
	tcp_recv(newpcb, recv_callback);
	/* just use an integer number indicating the connection id as the
	   callback argument */
	tcp_arg(newpcb, (void*)connection);
	/* increment for subsequent accepted connections */
	connection++;
	return ERR_OK;
int start_application()
	struct tcp_pcb *pcb;
	err_t err;
	unsigned port = 7;
	/* create new TCP PCB structure */
	pcb = tcp_new();
	if (!pcb) {
		xil_printf("Error creating PCB. Out of Memory\n\r");
		return -1;
	/* bind to specified @port */
	err = tcp_bind(pcb, IP_ADDR_ANY, port);
	if (err != ERR_OK) {
		xil_printf("Unable to bind to port %d: err = %d\n\r", port, err);
		return -2;
	/* we do not need any arguments to callback functions */
	tcp_arg(pcb, NULL);
	/* listen for connections */
	pcb = tcp_listen(pcb);
	if (!pcb) {
		xil_printf("Out of memory while tcp_listen\n\r");
		return -3;
	/* specify callback to use for incoming connections */
	tcp_accept(pcb, accept_callback);
	xil_printf("TCP echo server started @ port %d\n\r", port);
	return 0;
//////////////////////////RX code /////////////////////////////
#include "xparameters.h"
#include "xil_exception.h"
#include "xstreamer.h"
#include "xil_cache.h"
#include "xllfifo.h"
#include "xstatus.h"
#include "ar_rx.h"
#undef DEBUG
XLlFifo FifoInstance;
int aurora_rx_main()
	u32 RxWord;
	int Status;
	//xil_printf("Entering RX loop\r\n");
	//while(1)
	Status = XLlFiforx(&FifoInstance, FIFO_DEV_ID);
	if (Status != XST_SUCCESS)
		xil_printf("Axi Streaming FIFO Test Failed\n\r");
		return XST_FAILURE;
	xil_printf("Successfully ran Axi Streaming FIFO \n\r");
	return XST_SUCCESS;
int XLlFiforx(XLlFifo *InstancePtr, u16 DeviceId)
	//xil_printf("######\n\r");
	XLlFifo_Config *Config;
	int Status,n=0;
	Status = XST_SUCCESS;
	/* Initialize the Device Configuration Interface driver */
	Config = XLlFfio_LookupConfig(DeviceId);
	if (!Config)
		xil_printf("No config found for %d\r\n", DeviceId);
		return XST_FAILURE;
	Status = XLlFifo_CfgInitialize(InstancePtr, Config, Config->BaseAddress);
		xil_printf("Initialization failed\n\r");
		return Status;
	while(n<10)
	Status = RxReceive(InstancePtr, DestinationBuffer);
		xil_printf("Receiving data failed");
		return XST_FAILURE;
	n++;
	return Status;
int RxReceive (XLlFifo *InstancePtr, u32* DestinationAddr)
	int i;
	//int Status;
	u32 RxWord;
	static u32 ReceiveLength;
	ReceiveLength = (XLlFifo_iRxGetLen(InstancePtr))/WORD_SIZE;
	/* Start Receiving */
	if(ReceiveLength>0)
		//xil_printf("@@@@@@@@@ ");
	for ( i=0; i < ReceiveLength; i++)
		RxWord = 0;
		RxWord = XLlFifo_RxGetWord(InstancePtr);
		*(DestinationAddr+i) = RxWord;
		//*(DestinationAddr+i) = 10;
		xil_printf("received data : %d\n\r",*(DestinationAddr+i));
return XST_SUCCESS;
 I have modified my code. I think now experts can answer to my question.
aurora_rx_main() // Functional call receiving the data from FIFO and passing that data to TCP.
whether my design flow is right ? I need to read the array of integer values (counter data) in PC through Putty or Tera.
	int i,Status;
	Status=aurora_rx_main();         ///FUNCTION CALL
	for(i=0;i<10;i++)
	if (!p) {
		tcp_close(tpcb);
		return ERR_OK;
	if (tcp_sndbuf(tpcb) > 10) {
	err = tcp_write(tpcb, DestinationBuffer, 10, 1);
	} else
	pbuf_free(p);
	return ERR_OK;
Hi @thaus_015,
I just little confused about your question. where your counter is running? I assume the counter is running on PC, am I correct?
From where to where you have to send the data? I mean from PC to KC705 board or KC705 board to PC.
the recv_callback() function is called when ever the board receives data from the PC. if the counter data is coming from PC then the data is available in  p->payload variable. you can read the p->payload variable and then use it.
In case if you want  to write the data to the PC from the kc705 board then use the tcp_write() function.
Best Regards,
Srikanth
Thanks for your response. Sorry for confusion. My goal is to write the data to the PC from the kc705 board.
Design Flow as follows as below
1. Counter data from Kintex DAQ board (Part Number : XC7k160tffg676-2) is passing to the KINTEX KC705 board through optical cable
2. KINTEX KC705 board Should pass the data to PC through LWIP Echo server.
I am stuck From KC705 to PC
	int i;
	//int Status;
	u32 RxWord;
	if(ReceiveLength>0)
		RxWord = 0;
return XST_SUCCESS;
From above code, i am able to collect the data in KC705 and now i need to pass same data to TCP and read the data in PC.
 Now please suggest me what is procedure ? How to pass the received data from KC705 to PC, and I need to read the data in PC either in Tera or Putty.
Please response me. Thanks
I have edited Echo template code as per your suggestion through tcp_write function. Please conform me whether the below code is right ?
extern u32 DestinationBuffer[1024];   // Globally Declared : Counter Values are stored in destination buffer. Those values i am passing to tx_func. That function is called in recv_callback.
extern void tx_func(struct tcp_pcb *tpcb)
int i,Status;
for(i=0;i<1024;i++)
tcp_write(tpcb, DestinationBuffer, 1024, 0);
	if (!p) {
		tcp_close(tpcb);
		return ERR_OK;
	tx_func(tcp_pcb)
	} else
	pbuf_free(p);
	return ERR_OK;
Hi @thaus_015,
once you received the data from the FIFO then load the complete data into the buffer and then use the tcp_write() function to send the data to the PC.
Here instead of the p->payload user your buffer and p->len is the lenght of the buffer.
for example you stored the received data from the FIFO in a DestinationAddr register and length is ReceiveLength then you can send the data to PC by calling the below function.
tcp_write(tpcb, *DestinationAddr , ReceiveLength 1);
then the FIFO data that you received from the DAQ board will be sent to PC.
Note: you are running the LWIP echo server example which means the KC705 board act as a Server and it need to connected to a slave before it sending anything over the ethernet (using tcp_write function).
The modified application is expected to be work. but you need to send some data from the PC then only it will send the daq data to your PC.
Best Regards,
Srikanth
  Thanks for your response. As per your i have modified the code and run the program.
Yes, PC will send some data , and then KC will send the data to PC.
I am using Hercules to read the data, where in Hercules it accepts String.
So i am doing Integer to String Conversion.
char buf[32] = {0};
	return 0;
 int i = 30;
return &buf[i+1];
	int i,j,Status;
	for(i=0;i<10;i++)
		xil_printf(" Data:%d,",DestinationBuffer[i]);
	int base=10; // here 10 means decimal
  char *result={0};
  result= itoa(DestinationBuffer[0],base);
	if (!p) {
		tcp_close(tpcb);
		return ERR_OK;
		err = tcp_write(tpcb,result,10,1);
	} else
	pbuf_free(p);
	return ERR_OK;
I am able to read single data from Destination Buffer in Hercules. Please suggest me how to make the LOOP of
Please find the Screenshot of result
Sorry, One more update actually i need to read the all data in Python Shell without using Hercules. Any suggestion.
Please response for my two previous posts.
I am able to read the continuous DestinationBuffer data in Hercules using itoa function with some Junk characters. How to clear that Junk ?
Actual data flow should be Data:1050842703, Data:1050842704, Data:1050842705, Data:1050842706, Data:1050842707, Data:1050842708, Data:1050842709, Data:1050842710, Data:1050842711, Data:1050842712,
but I am able to read the data in Hercules but without any comma or else some Junk characters are printing with data
e105084270310508427041050842705105084270610508427071050842708.
char buf[64] = {0};
//extern u32 DestinationBuffer[10];
	return 0;
 int i = 62;
return &buf[i+1];
	int i,j,Status;
	for(i=0;i<50;i++)
    char *result={0};
	if (!p) {
		tcp_close(tpcb);
		return ERR_OK;
	if (tcp_sndbuf(tpcb) > 50) {
		 for (j=0;j<=50;j++)
		    result= itoa(DestinationBuffer[j],base);
		     //err = tcp_write(tpcb,",",50,1);
		    err = tcp_write(tpcb,result,50,1);
	} else
	pbuf_free(p);
	return ERR_OK;
Hercules ScreenShot
