LWIP error in EDK12.1
 hi..
i m using Virtex-4 FX12 minimodule and i m using EDK12.1 for development..
i m including LWIP library (through software platform settings) in my application....while compliling the project
it gives error
(undefined reference to "lwip_write")
and same error for all lwip funcions which are used in application..
this seems that it is problem of including the lwip library but i hav includes lwip library in
software platform settings---->os and library settings
here i have checked lwip in checkbox
in the application code i have also included the header files
#include "lwip/sockets.h "
but if i use edk10.1+ sp3 and make an application (using lwip)over there ..same type of application complies and run without any problem....
now i m stuck at this stage....i dont  understand how to fix it...
can any body help me regarding this problem..
thanks.
Re: LWIP error in EDK12.1
Right Click over the application.
Go to Set Compiler options.
Go to Path and Options tab.
Make sure the Libraries to link as shown in compiler_settings.JPG attached.
Thnx
Did you check the api_mode for LWIP to SOCKET_API? By default it;s RAW_API mode.
"Don't forget to reply, kudo and accept as solution."
ya i have checked the API mode it is SOCKET_API
can you tell how you set the software plateform settings for lwip
sujeet
Thnx
thanks...
i was not  doing complier settings options thats why libraries were not getting linked..
