Observer kcraft
Libraries (-l) vs bsp compile issue.
I've repeatedly had this issue when I tell the BSP to include a library and code works then one day it stops compiling correctly. I then disable the library in the BSP, recompile, reenable the library in BSP and build. This typically fixes the problem.
In a previous post :
http://forums.xilinx.com/t5/Embedded-Development-Tools/SDK-14-7-debug-compile-issues/m-p/457650
It was explained that I should use lwip4 in my applications libraries(-l) settings. This resolved the issue since it was always happening with the LWIP libraries.
I just reencountered the issue but this time with the Xilflash library. I found that including "xilflash" was enough to resolve my immediate problem.
Question: where can I find a list of all the libraries -l commands that relate to the different libraries I use? I don't want to have to remember how to resolve this problem each time I add a new library or one that I've been using decides to not link.
Thanks in advance.
Re: Libraries (-l) vs bsp compile issue.
Let us try to list down the options:-
-lxilkernel(refer to socket bsp of XAPP1026)
-lxilflash (refer to ML605 BIST hello_flash application)
-llwip4 (refer to xapp1026)
-lxilisf (refer to xapp1034)
--Hem
Scholar sampatd
By default, the compiler searches only the standard libraries, such as libc, libm, and libxil.
You may also try adding -L (Lib Directory) to search for the libraries in the path provided.
