woitha
Linker problem with xilffs
I am using Vivado 17.2 with a Zybo-Board. I am trying to read/write files on a SDCARD (FAT32) with the „xilffs“ library.
I started with the  “xilffs_polled_example” (adding it to my sources / standalone project) and it works fine.
The next day I restarted Vivado and the SDK, and now I got the following linker errors, when cleaning the project:
./src/sdcard.o: In function `FfsSdPolledExample':
sdcard.c:(.text+0x5c): undefined reference to `f_mount'
sdcard.c:(.text+0x80): undefined reference to `f_mkfs'
sdcard.c:(.text+0x9c): undefined reference to `f_open'
sdcard.c:(.text+0xac): undefined reference to `f_lseek'
sdcard.c:(.text+0xcc): undefined reference to `f_write'
sdcard.c:(.text+0xdc): undefined reference to `f_lseek'
sdcard.c:(.text+0xfc): undefined reference to `f_read'
sdcard.c:(.text+0x128): undefined reference to `f_close'
It works again, when I am modifying the BSP settings:
  1. Remove “xilffs” from BSP
  2. Add “xilffs” to BSP
But after restarting the SDK, the problem occurs again.
I have also found out, that the objects.mk file did not contain the “lxilffs”, after restarting the sdk.
LIBS := -Wl,--start-group,-lxil,-lgcc,-lc,--end-group
But should be:
LIBS := -Wl,--start-group,-lxil,-lgcc,-lc,--end-group -Wl,--start-group,-lxilffs,-lxil,-lgcc,-lc,--end-group
I am doing something wrong? Is it a bug? Is there another workaround excepting the one I have found?
florentw
Hi @woitha,
Which OS are you using?
Could you send a test case?
Florent
Florent
stephenm
If the linker options arent getting correctly populated after you add the xilffs to the BSP, then this is a bug.
woitha
Hi Florent,
I am using Windows 10 Pro x64 latest release.
I generated a new project with the “xilffs_polled_example” and this time the problem does not occur. However I do not like to restart my complete project.
That’s why I have copied my project and deleted everything except the Prozessing-System and the “xilffs_polled_example”. This is now almost the same project I have generated before, but now the problem still exists. Perhaps you can have a look at this project (VideoProzessor.xpr.zip).
  1. Start Vivado
  2. Open the VideoProzessor project
  3. Launch SDK
  4. Clean should generate the described errors
  5. Modify BSP (remove xilffs)
  6. Modify BSP (add xilffs) again
  7. Clean should work without errors
  8. Close SDK
  9. You may continue with 3. again
By the way, there is also another strange thing. Every time I am generating a new bitstream and exporting the hardware (with bitstream), the SDK shows the new hdf-File but still  the old bitstream. Currently I am always deleting the hw_platform in SDK before exporting new hardware in vivado. However I do not think this is way it should work.
Thank you in advance for your help!
Dirk
florentw
Hi @woitha,
This is a known issue of SDK 2017.2. Please check AR#69489, there is a workaround.
This AR should be updated with a script for a more convenient workaround.
I will have a look to your project and let you know what I have found.
Florent
Florent
meakerb
Is there a response for this issue? I am having the same issue (although running SDK 2016.4) and cannot figure out what to do.
a@1
The methods are not working..thoigh i have added, required preprocessors,f_open is still showing undefined reference
I think that xilffs library is not automatically linked.
Manually link it.
SDK Properties -> C/C++ Build -> Settings -> gcc linker -> Inferred Options -> Software Platform
In Software Platform Inferred Flags options, add '-lxilffs'.
fircrestsk8
Confirmed this is still an issue in 2018.3. Manually linking as described in the post above seemed to do the trick, though I used:
SDK Properties -> C/C++ Build -> Settings -> gcc linker -> ARM v8 gcc linker -> Libraries
and then added a library (-l) called xilffs. That did the trick.
If you are version controlling your project this change will be captured in the .cproject file for the application project.
