XHW
Linux_Domain creation error
When I follow the UG-1209: Ch. 6 --> design Example 1 --> Configure Software --> Creating the Linux Domain for Linux Application, I got the following error:
Note that I followed the UG-1209 to create the edt_zcu102_wrapper.
Thank you in advance for your help and support!
Best regards,
XHW
marcb
Hi @XHW
If your Linux boot components are 32-bit, can you try making the application 32-bit as well?
XHW
Hi @marcb
Thank you for your reply!
Yes, I can; but I wonder why I got such error when I followed UG1209 and how I can fix such error if it happens in future.
Best regards,
XHW
marcb
Hi @XHW
Is this the 2020.1 version of the tools and UG1209 or another version?
XHW
Hi @marcb
Yes, both Vitis and UG-1209 are 2020.1 version.
Best regards,
Xinhua
marcb
Hi @XHW
Can you try selecting the psu_cortexa53 SMP for the processor? I see the error when selecting psu_cortexa53_0, but not the psu_cortexa53 SMP.
I will report this to the documentation team, as the psu_cortexa53 SMP is only visible in 2020.1 after selecting the "Show all processors" checkbox.
XHW
Hi @marcb
Thank you for your support and sorry for the late reply because I am busy.
The problem occurs at Step 4 on pp.156-157 of UG1209 (v2020.1) June 3, 2020.
According to UG-1209:  Processor: psu_cortexa53_0
However, available from the drop down menu: Processor: psu_cortexa53
There is no psu_cortexa53 SMP as you mentioned. See below:
When I click OK button, I got the error reported.
Anyway, I have made it work using ZCU111. It is not a problem. So, let's not to spend time on this anymore.
Best regards,
XHW
