(Linux) ERROR : (XSDB Server)ERROR: [Hsi 61-13] No current software db available
I am getting errors when trying to create an Application Project in XSDK on Linux.
I created a Hardware Platform Specification project from a hdf file, and that was successful.
I get the error(s) when I try and create an Application Project. An error window pops up and says:
16:49:29 ERROR : The Hardware Project referenced by this BSP (UltraZed_open_amp_bsp) was not found in this workspace. As a result, this BSP will not build properly. To fix this error, please import the associated hardware project or recreate a new BSP targeting an existing hardware platform.
But there are earlier errors in SDK.log:
16:49:26 ERROR : (XSDB Server)ERROR: [Hsi 61-13] No current software db available.
16:49:26 ERROR : Failed to call write_mss
Reason: ERROR: [Common 17-39] 'hsi::write_mss' failed due to earlier errors.
The Hardware Project referenced by the Application Project was created successfully, and is clearly visible and available in the Eclipse Project Explorer.
Any help will be much appreciated.
Hi @sbhandari.doble.com
Are you still dealing with this issue? Not sure what's going wrong but might be something related to project names?? I would suggest you to increase the SDK log level (Trace) to check if we can get more information there.
Ibai
Ibai
