Observer nikitagusev95
Load C Code on DDR3
Problem:
After loading the .bit file onto flash I want to be able to load C code through the UART onto the DDR3 for the FPGA Microblaze to execute. (Is this possible?) End goal is to load C code files from Labview for the Microblaze to execute.
Background Information:
I am able to load code onto the FPGA through the Xilinx SDK, and I am able to load a small sample program using impact onto the flash by converting the .bit and .elf into a .mcs file. However I don't want to load it on flash, but on the DDR3.
I have run a "Memory Test" program and the DDR3 works.
I am looking for some guidance and suggestions, thank you very much.
Re: Load C Code on DDR3
hi,
do you want a bootloader? if yes, refer to https://forums.xilinx.com/xlnx/attachments/xlnx/EDK/5498/1/Flashwriter_101.pdf
--hs
