loutronique
Locallink and DMA
Hi All,
I need to make a DMA transfert between a ddr2 and a bram.
So can i use the do this by connecting the LocalLink interface to xps_LL_fifo which will be connected to the plb_bus(the bram is connected to the plb) ?
I am using a powerpc and xps for the first time.
Thank you for the help.
regards
lounes
shuns
Possibly not. It sounds like to me, from your description,  you would like connect the MPMC SDMA PIM through the LL_FIFO to the xps_bram on the PLB bus. Although this is logically possble, it won't work.
To explain a little bit, the SDMA engine can move through data with a master peripheral (for example, xps_ll_temac) connected to it. It requires the LL peripheral to be able to initiate a transaction on the LL interface (for example, when xps_ll_temac receives a packet) as well as receving data from the SDMA engine (for example, a user needs to transmit a packet). But nether the xps_bram nor xps_ll_fifo has this kind of function.
Local link and SDMA might not be an easy concept to understand for a first time user. To start with, I would suggest keep it with the PLB bus and use the central DMA core to move data around. Although the performance won't be as high as SDMA, it is nonetheless a proven solution and all the necessary cores (MPMC, xps_central_dma, xps_bram) are readily available for you to create a working system quickly.
Hope this will help you.
-Yan Shun Li
shuns
-Yan Shun Li
loutronique
thank you shuns for your answe,
I will try to use the central dma but i just have an other question to be sure .
is there a linux driver to configure the dma with the powerpc because i only found standalone drivers ?
shuns
Unfortinately, on the Linux front, there is no driver for the central DMA yet. You may have to write your own.
Sorry :(
Yan Shun Li
loutronique
thank you again shuns i will try to make the driver myself
