pcaddick
MFS files
I have used mfsgen -cvbf to create an mfs file. I have then downloaded this onto the hardware before lauch.
I want to then update files in the mfs file in the software. I'm able to identify the files within the MFS file and open them using mfs_file_open(filename, MFS_MODE_READ). I can also see its size using fsize = mfs_file_lseek(fd, 0, MFS_SEEK_END); However if I want to update the file I don't see a command that allows me to do this.
I have looked thro http://www.xilinx.com/ise/embedded/edk82i_docs/sa_xilmfs_v1_00_a.pdf and this doesn't explain how you can update the file. Any suggestion please?
Pete
pcaddick
all sorted now :)
balkris
mfsgen -cvbf ../image.mfs 2048 css images js yui generate-mfs index.html
This command is described on page 18 of the LightWeight IP (lwIP) Application Examples Application Note (XAPP1026):
http://www.xilinx.com/support/documentation/application_notes/xapp1026.pdf
Thanks and Regards
Balkrishan
pcaddick
Hi @balkris
I know that I can update the file by rerunning mfsgen -cvbf what I want to be able to do is update the file within the SDK software. The method you suggests mean I have to reload the software everytime to update the mfs file. I want to be able to do it within the code.
I am trying to use  mfs_file_write(fd, pixel, 1); where fd is the file, pixel is the data. This doesn't work. I'm able to delete the file with mfs_delete_file(filename);
Pete
sampatd
Check the MFS functions on page 126 of the following guide:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/oslib_rm.pdf
pcaddick
thanks but this is a repeat of http://www.xilinx.com/ise/embedded/edk82i_docs/sa_xilmfs_v1_00_a.pdf which also doesn't explain the mfs functions very well
pcaddick
all sorted now :)
