tmonaghan84
MPSoC/SDK/Petalinux Ada Support?
I am wondering if anyone else has tried Ada support on Petalinux/MPSoC.
I would like to inherit some legacy Ada code, for use on the APU running Petalinux.
1) Do Xilinx support Ada?
2) Is this planned for the future?
3) Does Petalinux support Ada?
4) Any advise on creating a toolchain for this?, https://crosstool-ng.github.io/
Thanks in advance.
Tim
ibaie
Hi @tmonaghan84
Xilinx does not support ADA and as long as I'm aware there is no future planning on this.
Ibai
ibaie
Hi @tmonaghan84
Ibai
