Visitor jonortega
Makefile error with ZEDBoard
Hi!
I'm a complete newbie onto Xilinx FPGAs.
I am starting to work with the ZEDBoard.
Following the first example, I define and configure the hardware system with Vivade IDE.
Then I try to create a software application with the SDK. I try to create an empty application, but I get errors in the Makefile:
make: *** [ps7_cortexa9_0/libsrc/devcfg_v3_2/src/make.libs] Error 2    LED_test_bsp             C/C++ Problem
It seems that there is some library that is not being loaded properly?
How can I fix it?
I have run the same system in another computer with no problem, but I am unable to make it run in my own.
Thanks in advance for your help.
Screenshot from 2015-06-15 14:32:06.png
Re: Makefile error with ZEDBoard
@jonortega
Are you using Ubunutu Machine ?
I think you may be missing some 32-bit libraries  and so you are seeing this issue.
Achutha
Visitor jonortega
Thanks for your help achutha.
Nice guess: I am running Ubuntu on a 64 bits machine.
I have downloaded and installed  the Vivado Design Suite Full Product.
How can I tell if it is choosing properly the 64 or 32 bits libraries?
In the project settings I can see that the default library is: xil_defaultlibVivado 32 64 bits
hi,
which version of SDK have you installed? If it is 2015.1 then it only has 64-bit install version
--hem
Visitor jonortega
I have tried the latest one: 2015.1
And after testing it and finding this problem I have installed the 2014.4, which is the one that has been installed in another computer and works fine.
I get the same error with both versions.
hi
can you type in the console,  make -v in both the working/failing machines?
if the versions do not match, then you might have to install the make version.
--hem
Visitor jonortega
Sure, here you have the version I get.
For the 2015.1:
GNU Make 4.0
Built for x86_64-pc-linux-gnu
Copyright (C) 1988-2013 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
For the 2014.4:
GNU Make 4.0
