Mask interrupts while debugging
I'd like to mask the interrupts of my MicroBlaze system while I step through my application code. The execution continually jumps to the ISR dispatcher which makes it hard to debug the rest of the code.
My setup consists of the following:
- Kintex7 with MicroBlaze conifgured
- SDK 2014.1
- TCF debug session connected via USB-JTAG to KC705 board
Can anyone help, pease?
Chris
Anonymous
Not applicable
Re: Mask interrupts while debugging
You could set a breakpoint at the start of your application. in the Breakpoint, you can set an action. In the action you can call the xmd.exe with a tcl file that will write to the interrupt controller IER register to mask the interrupts out.
I have attached a doc showing how to set actions on breakpoints. For infor on the interrupt controller, you can see its datasheet
Another way might be to disable interrupt in MicroBlaze in XMD.
MicroBlaze MSR register contains a IE bit (bit 30) which is set when MicroBlaze accept interrupts.
Just read the current value with
> rrd msr
change the value by setting bit 30 to '0' and write back the new value to MSR with
> rwr msr value
When you want to enable interrupts again, just repeat the above sequence but now set the IE bit to '1'.
Göran
