ank_mistry
Matching ADDRESS_SPACE for code segment #1 not found in 'sys tem_bd.bmm'.
Hello All,
              I'm getting error when i try to generate the .bin file.check below the command and the error
C:\*****\****\*****\*****\BIN>data2mem -bm system_bd.bmm -bd system1.elf -bt system.bit
ERROR:Data2MEM:33 - Matching ADDRESS_SPACE for code segment #1 not found in 'sys
tem_bd.bmm'.
Code segment #1 occupies [0x48000000:0x48002703]turnV3Test.bit
  can i get any help on this!!!!!!
Anonymous
Not applicable
This error is saying that the data file (either MEM or ELF) oes not have any data that is specified in the address range in the BMM file.
You need to fix this by changing the BMM file, or the ELF file (linker), or the MEM file so the data is within this region
sampatd
Please check the following AR to understand why this error occurs:
http://www.xilinx.com/support/answers/21121.html
ank_mistry
Thanks for the help.
I know the address map is not proper,but i then too want to add the .elf file. I even tried undating the linker script but that too didn't work.I will add the flash and try it out.
Any suggestion please do tell.
sha@hys
 Did you solve the problem??? I have a saturn V3 board and has same error with data2mem.
Tags (2)
Anonymous
Not applicable
ank_mistry
Yes, I did rebuild the project and updated the linker script. I does solve the problem.
I did that long back, sorry for late reply.
