Memory read error at 0xF8000008: Cannot read write-only register
I am using Zynq-7000,
  • I can program the Zynq- boot flash memory succesfully,
  • Zynq is seen properly boot-up from flash. Done led lights up
  • I can even communicate with Zynq via Ethernet for near 10 seconds.
  • After this 10 seconds later, something has gone wrong and ethernet connection is gone, even processor is seen halted.
  • I tried many times, behaivor of Zynq is like that.
  • Then, I decided to try to debug a basic memory test generated by SDK. Ups. I received error  "Memory read error at 0xF8000008: Cannot read write-only register" . I can not even debug the ARM.
  • I have looked at Zynq register 0xF8000008 that is seen write-only as attached from TRM.
  • Why does Zynq try to read this write-only register 0xF8000008 ?
  • May not the PS initialization be done properly after the power-on?
Waiting for replies,
Thank you !
Re: Memory read error at 0xF8000008: Cannot read write-only register
Which version of SDK are you using. From 2016.x, hw_server throws an error if an attempt is made to read WO regs (ps_init.tcl uses mask_write command to write to WO registers too). SDK should catch this error and throw a warning.
A simple workaround is to start hw_server manually, connect to it from xsdb/xsct, and run the command 'configparams force-mem-accesses 1'. This will suppress the memory access protection, so when you launch debug from SDK after this, you shouldn't see the error you mentioned
Dear @sadanan,
*Which version of SDK are you using.
It is 2016.3
I wil try your suggestions to overcome the problem.
Thank you.
Tags (5)
