KKilic
Memory read error at 0xF8F00208. Cannot halt processor core, timeout
I am trying Hello World application on Zybo Z7-20 and get error:
Memory read error at 0xF8F00208. Cannot halt processor core, timeout.
After making some Google search, I found that someone mentioned that it might be power issue, so I changed to wall power supply but still it didn`t work.
PL design is so simple. Any help is appreciated.
derekm_
Voyager
Voyager
I've checked the XSA, it works fine when the boot jumper settings (JP5) are set correctly to JTAG. I can repeat your error by changing the boot settings to QSPI or SD Card. So make sure that you have the settings set to JTAG (see below). Power off the board first, change the the jumper to JTAG, power-on, re-run your program. You may need to rebuild or clean the program before you re-run it, to tidy up from the earlier error. See how you get on with this.
stephenm
Are you using the preset settings for the zynq PS in Vivado? If not, can you try this?
KKilic
Yes I haven`t change anything.I was just following tutorials for basic Hello World application.
stephenm
Can you share the log? where exactly do you see this? id this during the ps7_init?
KKilic
yes. Please find logs below.
KKilic
Any help?
derekm_
Voyager
Voyager
If you want to attach the XSA file for your project, I will test it on a Zybo-Z7-20 and see what happens.
KKilic
Hi Derekm,
please find xsa attached.
derekm_
Voyager
Voyager
KKilic
Thank you very much.
