sridar-s
Memory update issue
I am trying to create the simple AXI Master in PL and interfaced to S_AXI_HP1_FPD port on Zynq XCZU9EG device. The software code on SDK is a very basic one to continuously read the data on the target memory address locations. I don't see the updated values on memory locations in the software unless I exit the debug session and re-run the code. It's the same behavior on memory window as well. Any help on this ?
P.S. I use ZCU102 Eval board with Vivado 2017.4.
stephenm
stephenm
sridar-s
It worked! Thanks.
stephenm
