Merging bitstream with .elf not working 2018.1
I'm trying to merge the .elf and .bit file in SDK and use the generated download.bit file. Unfortunately, this is not working.
I've tried associating .elf in vivado too, but here too I'm facing the same issue.
Please let me know what could be the problem here?
Is any there a proven way ?
Vinay
Vinay Shenoy
Re: Merging bitstream with .elf not working 2018.1
Hi @vinay_shenoy,
Using URAM is not possible because there is no user defined INIT attribute and therefore the connect of RAM array cannot initialized to user defined values.
Please check the Ultra RAM key features in below guide: https://www.xilinx.com/support/documentation/user_guides/ug573-ultrascale-memory-resources.pdf
Please use the BRAM memory.
Best Regards,
Srikanth
Hi @vinay_shenoy,
are you using the BRAM for macro blaze? is the micro blaze instant is same ?
Please check once.
Best Regards,
Srikanth
Hi @savula
I have used URAM for Microblaze. Is this possible?
Vinay
Vinay Shenoy
Hi @vinay_shenoy,
Best Regards,
Srikanth
