Visitor estradjm
MicroBlaze Hello World SDK Example Error with 2017.3 and Ubuntu 16.04 on KC705 Development board
Hi, I am running Ubuntu 16.04, Vivado 2017.3 and the corresponding Xilinx Software Development Kit, Release Version: 2017.3. I am targetting the Kintex 7 KC705 development board, and I am simply following the directions found in this quick start guide: https://www.xilinx.com/support/documentation/quick_start/microblaze-quick-start-guide.pdf . I have enabled the debug level output into the SDK Log if that might shed any light. I have tried searching for answers to this problem, and tried everything I have found on the forums without any success.
One thing that has crossed my mind is that the forums have indicated that PetaLinux relies on 32 bit libraries, and I am on a 64 bit machine and cannot get the right 32 bit dependencies called out in another post, as they do not seem to exist and throwing a wildcard into the apt-get doesn't find them either. That is not relevant yet, I think, as my issue seems to be with the SDK generation of the example project, not PetaLinux yet.
I mention the 32 bit and 64 bit clash as well, because of this other forum response to a similar error message from a different application:
https://askubuntu.com/questions/398929/unable-to-load-shared-object-wrong-elf-class-elfclass32
But if I have other versions of Vivado and the driver works for them, 2017.4, 2015.4, and 2016.4, why would it suddenly be a problem in 2017.3? Is there a mismatch with the 32 bit and 64 bit versions somehow? There is only one option for both Vivado Design Suite HLS Edition for Linux in each version possible and SDK for that specific version of Vivado, so I don't think it is likely.  That then leaves the libusb-driver.so in question, but if it worked with other versions of Vivado, older and newer, then it should work in this version of Vivado, I would assume.
Anyways, any help with the current issue is greatly appreciated.
 Below is the verbose output of the SDK Log.
16:45:02 DEBUG	: XSCT Command: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Thread: main
16:45:02 DEBUG	: XSCT command with result: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Result: [null, ]. Thread: main
16:45:02 DEBUG	: XSCT Command: [::hsi::utils::get_all_app_details -json], Thread: main
16:45:02 DEBUG	: XSCT command with result: [::hsi::utils::get_all_app_details -json], Result: [null, {"zynq_dram_test": {"userdefname": "Zynq DRAM tests",
"description": "This application runs out of OCM and performs memory tests and read/write eye measurements on Zynq DRAM.  For more information about the test, refer to ZYNQ_DRAM_DIAGNOSTICS_TEST.docx, in the src directory of the application",
"supp_proc": "ps7_cortexa9",
"supp_os": "standalone",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/zynq_dram_test",
"os": "standalone",
"freertos_lwip_echo_server": {"userdefname": "FreeRTOS lwIP Echo Server",
"description": "The FreeRTOS lwIP Echo Server application provides a simple demonstration of how to use the light-weight IP stack (lwIP) with FreeRTOS. This application sets up the board to use IP address 192.168.1.10, with MAC address 00:0a:35:00:01:02. The server listens for input at port 7 and simply echoes back whatever data is sent to that port.",
"supp_proc": "psu_cortexa53 psu_cortexr5 ps7_cortexa9 microblaze",
"supp_os": "freertos901_xilinx",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/freertos_lwip_echo_server",
"os": "standalone",
"openamp_matrix_multiply": {"userdefname": "OpenAMP matrix multiplication Demo",
"description": " OpenAMP matrix multiplication application ",
"supp_proc": "psu_cortexr5 ps7_cortexa9",
"supp_os": "freertos901_xilinx standalone",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/openamp_matrix_multiply",
"os": "standalone",
"dhrystone": {"userdefname": "Dhrystone",
"description": "Dhrystone synthetic benchmark program.",
"supp_proc": "microblaze ps7_cortexa9",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/dhrystone",
"os": "standalone",
"peripheral_tests": {"userdefname": "Peripheral Tests",
"description": "Simple test routines for all peripherals in the hardware.",
"supp_proc": "ps7_cortexa9 psu_cortexa53 psu_cortexr5 microblaze",
"supp_os": "standalone xilkernel",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/peripheral_tests",
"os": "standalone",
"srec_bootloader": {"userdefname": "SREC Bootloader",
"description": "Simple bootloader for loading SREC images from non volatile memory. This program assumes that you have an SREC image programmed into BPI flash. The program also assumes that the target SREC image is an application for this processor that does not overlap the bootloader and resides in separate physical memory in the hardware. Typically this application is initialized into BRAM so that it bootloads the SREC image when the FPGA is powered up.
Don't forget to modify blconfig.h to reflect the physical address where your SREC image resides in non-volatile memory!",
"supp_proc": "microblaze",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/srec_bootloader",
"os": "standalone",
"freertos_hello_world": {"userdefname": "FreeRTOS Hello World",
"description": " FreeRTOS Hello World application",
"supp_proc": "psu_cortexr5 ps7_cortexa9 psu_cortexa53 microblaze",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/freertos_hello_world",
"os": "standalone",
"libmetal_echo_demo": {"userdefname": "Libmetal AMP Demo",
"description": "Libmetal AMP Application",
"supp_proc": "psu_cortexr5",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/libmetal_echo_demo",
"os": "standalone",
"xilkernel_thread_demo": {"userdefname": "Xilkernel POSIX Threads Demo",
"description": "This Xilkernel based application provides a simple example of how to create multiple POSIX threads and synchronize with them when they are complete. This example creates an initial master thread. The master thread creates 4 worker threads that go off to compute parts of a sum and return the partial sum as the result. The master thread accumulates the partial sums and prints the result. This example can serve as your starting point for your end application thread structure.",
"supp_os": "xilkernel",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/xilkernel_thread_demo",
"os": "standalone",
"empty_application": {"userdefname": "Empty Application",
"description": "A blank C project.",
"supp_proc": "microblaze ps7_cortexa9 psu_cortexa53 psu_cortexr5",
"supp_os": "standalone xilkernel freertos901_xilinx",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/empty_application",
"os": "standalone",
"openamp_echo_test": {"userdefname": "OpenAMP echo-test",
"description": " OpenAMP echo-test application ",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/openamp_echo_test",
"os": "standalone",
"mba_fs_boot": {"userdefname": "mba_fs_boot",
"description": "fs-boot for microblaze by Xilinx Inc..",
"supp_proc": "",
"supp_os": "",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/mba_fs_boot",
"os": "standalone",
"lwip_echo_server": {"userdefname": "lwIP Echo Server",
"description": "The lwIP Echo Server application provides a simple demonstration of how to use the light-weight IP stack (lwIP). This application sets up the board to use IP address 192.168.1.10, with MAC address 00:0a:35:00:01:02. The server listens for input at port 7 and simply echoes back whatever data is sent to that port.",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/lwip_echo_server",
"os": "standalone",
"srec_spi_bootloader": {"userdefname": "SREC SPI Bootloader",
"description": "Simple bootloader for loading SREC images from non volatile memory (SPI). This program assumes that you have an SREC image programmed into SPI flash already. The program also assumes that the target SREC image is an application for this processor that does not overlap the bootloader and resides in separate physical memory in the hardware. Typically this application is initialized into BRAM so that it bootloads the SREC image when the FPGA is powered up.
Update the serial_flash_family & serial_flash_interface in xilisf library in BSP settings!
Don't forget to modify blconfig.h to reflect the offset where your SREC image resides in non-volatile memory!",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/srec_spi_bootloader",
"os": "standalone",
"hello_world": {"userdefname": "Hello World",
"description": "Let's say 'Hello World' in C.",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/hello_world",
"os": "standalone",
"ddr_self_refresh": {"userdefname": "DDR self refresh",
"description": "This DDR self refresh application provides a simple demonstration of how to enter to/exit from DDR self refresh mode. This application runs on R5 out of TCM.",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/ddr_self_refresh",
"os": "standalone",
"openamp_rpc_demo": {"userdefname": "OpenAMP RPC Demo",
"description": " OpenAMP rpc-demo application ",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/openamp_rpc_demo",
"os": "standalone",
"rsa_auth_app": {"userdefname": "RSA Authentication App",
"description": "Used to RSA authenticate a user application",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/rsa_auth_app",
"os": "standalone",
"zynqmp_pmufw": {"userdefname": "ZynqMP PMU Firmware",
"description": "Platform Management Unit Firmware for ZynqMP.",
"supp_proc": "psu_pmu",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/zynqmp_pmufw",
"os": "standalone",
"zynq_fsbl": {"userdefname": "Zynq FSBL",
"description": "First Stage Bootloader (FSBL) for Zynq. The FSBL configures the FPGA with HW bit stream (if it exists)  and loads the Operating System (OS) Image or Standalone (SA) Image or 2nd Stage Boot Loader image from the  non-volatile memory (NAND/NOR/QSPI) to RAM (DDR) and starts executing it.  It supports multiple partitions,  and each partition can be a code image or a bit stream.",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/zynq_fsbl",
"os": "standalone",
"zynqmp_dram_test": {"userdefname": "Zynq MP DRAM tests",
"description": "This application runs out of OCM and performs memory tests on Zynq MP DRAM.  For more information about the test, refer to ZYNQMP_DRAM_DIAGNOSTICS_TEST.docx, in the src directory of the application",
"supp_proc": "psu_cortexa53",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/zynqmp_dram_test",
"os": "standalone",
"memory_tests": {"userdefname": "Memory Tests",
"description": "This application tests Memory Regions present in the hardware.",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/memory_tests",
"os": "standalone",
"zynqmp_fsbl": {"userdefname": "Zynq MP FSBL",
"description": "First Stage Bootloader (FSBL) for Zynq Ultrascale+ MPSoC. The FSBL configures the FPGA with HW bit stream (if it exists)  and loads the Operating System (OS) Image or Standalone (SA) Image or 2nd Stage Boot Loader image from the  non-volatile memory (NAND/SD/QSPI) to RAM (DDR) and takes A53/R5 out of reset.  It supports multiple partitions,  and each partition can be a code image or a bit stream.",
"supp_proc": "psu_cortexa53 psu_cortexr5",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps/zynqmp_fsbl",
"os": "standalone",
"linux_empty_app": {"userdefname": "Linux Empty Application",
"description": "A blank Linux C project.",
"supp_proc": "ps7_cortexa9 psu_cortexa53 microblaze",
"supp_os": "linux",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps_linux/linux_empty_app",
"os": "linux",
"linux_hello_world": {"userdefname": "Linux Hello World",
"supp_os": "linux",
"path": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/sw_apps_linux/linux_hello_world",
"os": "linux",
}]. Thread: main
16:45:02 DEBUG	: XSCT Command: [::hsi::utils::is_app_supported_on_hw_sw  -hw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf -os standalone -processor microblaze_0 -app hello_world -sw {} -arch {}], Thread: main
16:45:02 DEBUG	: XSCT command with result: [::hsi::utils::is_app_supported_on_hw_sw  -hw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf -os standalone -processor microblaze_0 -app hello_world -sw {} -arch {}], Result: [null, 1]. Thread: main
16:45:10 DEBUG	: XSCT Command: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Thread: main
16:45:10 DEBUG	: XSCT command with result: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Result: [null, ]. Thread: main
16:45:11 DEBUG	: XSCT Command: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Thread: main
16:45:11 DEBUG	: XSCT command with result: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Result: [null, ]. Thread: main
16:45:12 DEBUG	: XSCT Command: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Thread: main
16:45:12 DEBUG	: XSCT command with result: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Result: [null, ]. Thread: main
16:45:17 DEBUG	: Application model: ApplicationModel [projName=Hello_world, projLoc=/home/jenniffer/plinux/hello_world/hello_world.sdk, hwPlatName=base_mb_wrapper_hw_platform_0, proc=microblaze_0, os=standalone, lang=C, bspName=Hello_world_bsp, appName=hello_world, newBsp=true, newHw=false, supportedOs={freertos901_xilinx=com.xilinx.sdk.sw.OS@119f606f, standalone=com.xilinx.sdk.sw.OS@7631b24f, linux=com.xilinx.sdk.sw.OS@76ccf580}, endianness=LITTLE, hwPlatform=com.xilinx.sdk.hw.internal.HwPlatform@478cc5f1, appGen=com.xilinx.sdk.appwiz.internal.AppGen@61646a62, extraCompilerFlags=, linuxSysRootPath=null, linuxSysRootPathSelection=false, linuxToolchainSelection=false, linuxToolchainPath=null, petalinuxProjectPath=null, specLocation=null, compilerType=32-bit, elType=N/A, projectBuildType=EXECUTABLE]
16:45:17 DEBUG	: XSCT Command: [::hsi::utils::write_sw_mss -hw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf -sw Hello_world_bsp -dir /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world_bsp -processor microblaze_0 -os standalone -app hello_world], Thread: main
16:45:17 DEBUG	: XSCT command with result: [::hsi::utils::write_sw_mss -hw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf -sw Hello_world_bsp -dir /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world_bsp -processor microblaze_0 -os standalone -app hello_world], Result: [null, ]. Thread: main
16:45:17 DEBUG	: Proc type microblaze and compiler type 32-bit
16:45:17 DEBUG	: Toolchain type
16:45:17 DEBUG	: Proc ID microblaze for getting proc type from preferences
16:45:17 DEBUG	: Toolchain type is MB for Proc ID microblaze
16:45:17 DEBUG	: ProcType = microblaze, corePrefId = com.xilinx.sdk.appwiz.preference.mb, toolchainPrefId = xilinx
16:45:17 DEBUG	: XSCT Command: [ ::hsi::utils::set_current_hw_sw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world_bsp/system.mss ], Thread: main
16:45:17 DEBUG	: XSCT command with result: [ ::hsi::utils::set_current_hw_sw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world_bsp/system.mss ], Result: [null, ]. Thread: main
16:45:17 DEBUG	: XSCT Command: [::hsi::utils::get_hw_sw_details -json /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world_bsp/system.mss], Thread: main
16:45:17 DEBUG	: XSCT command with result: [::hsi::utils::get_hw_sw_details -json /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world_bsp/system.mss], Result: [null, {"procname": "microblaze_0",
"osname": "standalone",
"osver": "6.4",
}]. Thread: main
16:45:17 DEBUG	: XSCT Command: [::hsi::utils::generate_bsp_sources /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world_bsp/system.mss /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world_bsp], Thread: main
16:45:17 DEBUG	: (XSDB Server)/opt/Xilinx/SDK/2017.3/gnu/microblaze/lin
16:45:17 DEBUG	: (XSDB Server)ERROR: ld.so: object '/home/jenniffer/Desktop/usb-driver-HEAD-2d19c7c/libusb-driver.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
16:45:17 ERROR	: (XSDB Server)ERROR: [Hsi 55-1545] Problem running tcl command ::sw_standalone_v6_4::post_generate : ERROR: ld.so: object '/home/jenniffer/Desktop/usb-driver-HEAD-2d19c7c/libusb-driver.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
    while executing
"exec $archiver -d $libgloss_a _interrupt_handler.o"
    (procedure "::sw_standalone_v6_4::post_generate" line 18)
    invoked from within
"::sw_standalone_v6_4::post_generate standalone"
ERROR: [Hsi 55-1443] Error(s) while running TCL procedure post_generate()
16:45:17 ERROR	: (XSDB Server)ERROR: [Hsi 55-1450] Error: running generate_bsp.
16:45:17 DEBUG	: XSCT command with result: [::hsi::utils::generate_bsp_sources /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world_bsp/system.mss /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world_bsp], Result: [{Format=ERROR: [Common 17-39] 'hsi::generate_bsp' failed due to earlier errors.
, Time=1531349117341, Code=1}, ]. Thread: main
16:45:17 DEBUG	: XSCT Command: [::hsi::utils::closesw /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world_bsp/system.mss], Thread: main
16:45:17 DEBUG	: XSCT command with result: [::hsi::utils::closesw /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world_bsp/system.mss], Result: [null, ]. Thread: main
"osver": "6.4",
}]. Thread: main
16:45:17 DEBUG	: Project Hello_world_bsp to be removed from workspace.
16:45:17 ERROR	: Error generating bsp sources: Failed in generating sources
Re: MicroBlaze Hello World SDK Example Error with 2017.3 and Ubuntu 16.04 on KC705 Development board
Can you install the libs below:
  • sudo apt-get update
  • sudo apt-get install libc6-i386
  • sudo apt-get install lib32z1
  • sudo apt-get install lib32stdc++6
Visitor estradjm
Hi Stephen,
Those libs are installed, and here is the terminal output:
jenniffer@raziel:0:~$ sudo apt-get update
Hit:1 http://repo.lanl.gov/repos/apt/debian trusty InRelease
Hit:2 http://security.ubuntu.com/ubuntu xenial-security InRelease
Hit:3 http://us.archive.ubuntu.com/ubuntu xenial InRelease
Hit:4 http://ppa.launchpad.net/ettusresearch/uhd/ubuntu xenial InRelease
Hit:5 http://us.archive.ubuntu.com/ubuntu xenial-updates InRelease
Hit:6 http://us.archive.ubuntu.com/ubuntu xenial-backports InRelease
Hit:7 http://ppa.launchpad.net/george-edison55/cmake-3.x/ubuntu xenial InRelease
Hit:8 http://repository.spotify.com stable InRelease
Hit:9 http://ppa.launchpad.net/gqrx/gqrx-sdr/ubuntu xenial InRelease
Hit:10 http://ppa.launchpad.net/mc3man/xerus-media/ubuntu xenial InRelease
Hit:11 http://ppa.launchpad.net/myriadrf/drivers/ubuntu xenial InRelease
Hit:12 http://ppa.launchpad.net/myriadrf/gnuradio/ubuntu xenial InRelease
Hit:13 http://ppa.launchpad.net/teejee2008/ppa/ubuntu xenial InRelease
Hit:14 http://ppa.launchpad.net/vincent-c/conky/ubuntu xenial InRelease
Reading package lists... Done
jenniffer@raziel:0:~$ sudo apt-get install libc6-i386
Building dependency tree
Reading state information... Done
libc6-i386 is already the newest version (2.23-0ubuntu10).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
jenniffer@raziel:0:~$ sudo apt-get install lib32z1
lib32z1 is already the newest version (1:1.2.8.dfsg-2ubuntu4.1).
jenniffer@raziel:0:~$ sudo apt-get install lib32stdc++6
lib32stdc++6 is already the newest version (5.4.0-6ubuntu1~16.04.10).
I restarted the PC, regenerated the bitstream, and exported it and opened up SDK, and tried to do the New Hello World Application Project again. Still not quite sure what the problem is. Below is the SDK Log output I get with the libs installed:
14:15:00 INFO	: Registering command handlers for SDK TCF services
14:15:01 DEBUG	: Creating XSCT command manager instance.
14:15:01 DEBUG	: Launch script file '/home/jenniffer/plinux/hello_world/hello_world.sdk/temp_xsdb_launch_script.tcl' contents:
set xsdb_idle_timeout -1;source /opt/Xilinx/SDK/2017.3/scripts/xsdb/xsdb/xsdb-server.tcl
14:15:01 INFO	: Launching XSCT server: xsct -n -interactive /home/jenniffer/plinux/hello_world/hello_world.sdk/temp_xsdb_launch_script.tcl
14:15:01 DEBUG	: Using default wait time 180 for XSCT launch
14:15:01 DEBUG	: (XSDB Server)
****** Xilinx Software Commandline Tool (XSCT) v2017.3
  **** Build date : Oct  4 2017-20:06:47
    ** Copyright 1986-2017 Xilinx, Inc. All Rights Reserved.
14:15:03 DEBUG	: (XSDB Server)XSDB Server URL: TCP:localhost:33338
xsct%
14:15:03 DEBUG	: Creating peer used for communication to XSCT server.
14:15:03 DEBUG	: Created xsdbPeer : xsdb-connect
14:15:03 DEBUG	: (XSDB Server)XSDB Server Channel: tcfchan#0
14:15:03 DEBUG	: XSCT server connection channel ID: tcfchan#0
14:15:03 DEBUG	: Adding the CommandServer
14:15:03 DEBUG	: Adding the CommandServer in Service XBuildSettings
14:15:03 DEBUG	: Registering Services: XBuildSettings, {}Xsdk
14:15:03 INFO	: XSCT server has started successfully.
14:15:03 DEBUG	: It has taken  2secs for XSCT server to launch.
14:15:03 DEBUG	: Script file '/home/jenniffer/plinux/hello_world/hello_world.sdk/temp_xsdb_launch_script.tcl' is deleted.
14:15:03 DEBUG	: XSCT Command: [set sdk::sdk_chan tcfchan#0], Thread: Thread-14
14:15:03 DEBUG	: XSCT Command: [::hsi::utils::init_repo], Thread: Worker-5
14:15:04 DEBUG	: (XSDB Server)WARNING: [Hsi 55-1434] Error /opt/Xilinx/SDK/2017.3/data/embeddedsw/XilinxProcessorIPLib/drivers/rfdc_v2_1/data/rfdc.mdd:49	 Unrecognized Option name. List of possible Option names are : DRC, DESC, COPYFILES, DEPENDS, SUPPORTED_PERIPHERALS, DRIVER_STATE, DEFAULT_OS, NAME, VERSION
14:15:04 DEBUG	: (XSDB Server)INFO: [Hsi 55-1698] elapsed time for repository loading 1 seconds
14:15:04 DEBUG	: XSCT command with result: [::hsi::utils::init_repo], Result: [null, ]. Thread: Worker-5
14:15:04 DEBUG	: XSCT command with result: [set sdk::sdk_chan tcfchan#0], Result: [null, tcfchan#0]. Thread: Thread-14
14:15:04 INFO	: Successfully done setting XSCT server connection channel
14:15:04 DEBUG	: XSCT Command: [setws /home/jenniffer/plinux/hello_world/hello_world.sdk], Thread: Thread-14
14:15:04 DEBUG	: XSCT command with result: [setws /home/jenniffer/plinux/hello_world/hello_world.sdk], Result: [null, ]. Thread: Thread-14
14:15:04 INFO	: Successfully done setting SDK workspace
14:15:04 INFO	: Processing command line option -hwspec /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper.hdf.
14:15:04 INFO	: Checking for hwspec changes in the project base_mb_wrapper_hw_platform_0.
14:15:04 DEBUG	: XSCT Command: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Thread: main
14:15:05 DEBUG	: XSCT command with result: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Result: [null, ]. Thread: main
14:15:05 INFO	: SDK has detected change in the last modified timestamps for source hardware specification file Source:1531426317000,  Project:1531420100000
14:15:05 INFO	: The hardware specification for project 'base_mb_wrapper_hw_platform_0' is different from /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper.hdf.
14:15:05 DEBUG	: XSCT Command: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Thread: main
14:15:05 DEBUG	: XSCT Command: [hsi get_hw_files -of_object [openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf ; hsi current_hw_design]], Thread: main
14:15:05 DEBUG	: XSCT command with result: [hsi get_hw_files -of_object [openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf ; hsi current_hw_design]], Result: [null, base_mb.hwh base_mb_bd.tcl base_mb_wrapper.bit base_mb_wrapper.mmi]. Thread: main
14:15:05 DEBUG	: It has  =4 number of files
14:15:05 INFO	: Copied contents of /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper.hdf into /base_mb_wrapper_hw_platform_0/system.hdf.
14:15:05 DEBUG	: XSCT Command: [::hsi::utils::closehw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Thread: main
14:15:05 DEBUG	: XSCT command with result: [::hsi::utils::closehw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Result: [null, ]. Thread: main
14:15:05 DEBUG	: XSCT Command: [::hsi::utils::openhw /tmp/system7002268553333514506.hdf], Thread: main
14:15:06 DEBUG	: XSCT command with result: [::hsi::utils::openhw /tmp/system7002268553333514506.hdf], Result: [null, ]. Thread: main
14:15:06 INFO	: Synchronizing projects in the workspace with the hardware platform specification changes.
14:15:06 INFO	: Clearing existing target manager status.
14:15:06 DEBUG	: Restoring previously saved JTAG Setting:
14:15:06 WARN	: Given IPC port value is invalid. Using default port 2350
14:15:06 WARN	: Given XMD timeout value is invalid. Using default value of 50000
14:15:06 DEBUG	: Unable to connect to port 2350. Retrying..
14:15:07 DEBUG	: Unable to connect to port 2350. Retrying..
14:15:08 DEBUG	: Unable to connect to port 2350. Retrying..
14:15:09 WARN	: Given XMD transaction timeout value is invalid. Using default value of 60000 milli seconds
14:15:09 DEBUG	: XMD command: {"command": "xdisable_digilent_plugin"}
14:15:09 DEBUG	: XMD Result: {"command":"xdisable_digilent_plugin","scope":{"type":"global"},"response":{"type":"success","success":{"values":["0"],"stdout":"Support for auto-discovery of Digilent Plugin turned OFF\n"}}}<-
14:15:09 INFO	: Workspace synchronized with the new hardware specification file. Cleaning dependent projects...
14:15:09 WARN	: Linker script will not be updated automatically. Users need to update it manually.
14:15:26 DEBUG	: XSCT Command: [::hsi::utils::get_all_periphs -json /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Thread: main
14:15:26 DEBUG	: XSCT command with result: [::hsi::utils::get_all_periphs -json /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Result: [null, {"axi_gpio_0": {"hier_name": "axi_gpio_0",
"type": "axi_gpio",
"version": "2.0",
"ip_type": "PERIPHERAL",
"axi_uartlite_0": {"hier_name": "axi_uartlite_0",
"type": "axi_uartlite",
"version": "2.0",
"clk_wiz_1": {"hier_name": "clk_wiz_1",
"type": "clk_wiz",
"version": "5.4",
"mdm_1": {"hier_name": "mdm_1",
"type": "mdm",
"version": "3.2",
"ip_type": "DEBUG",
"microblaze_0": {"hier_name": "microblaze_0",
"type": "microblaze",
"version": "10.0",
"ip_type": "PROCESSOR",
"microblaze_0_axi_periph": {"hier_name": "microblaze_0_axi_periph",
"type": "axi_interconnect",
"version": "2.1",
"ip_type": "BUS",
"microblaze_0_local_memory_dlmb_bram_if_cntlr": {"hier_name": "microblaze_0_local_memory_dlmb_bram_if_cntlr",
"type": "lmb_bram_if_cntlr",
"version": "4.0",
"ip_type": "MEMORY_CNTLR",
"microblaze_0_local_memory_dlmb_v10": {"hier_name": "microblaze_0_local_memory_dlmb_v10",
"type": "lmb_v10",
"version": "3.0",
"ip_type": "BUS",
"microblaze_0_local_memory_ilmb_bram_if_cntlr": {"hier_name": "microblaze_0_local_memory_ilmb_bram_if_cntlr",
"version": "4.0",
"microblaze_0_local_memory_ilmb_v10": {"hier_name": "microblaze_0_local_memory_ilmb_v10",
"type": "lmb_v10",
"version": "3.0",
"ip_type": "BUS",
"microblaze_0_local_memory_lmb_bram": {"hier_name": "microblaze_0_local_memory_lmb_bram",
"type": "blk_mem_gen",
"version": "8.4",
"ip_type": "MEMORY",
"rst_clk_wiz_1_100M": {"hier_name": "rst_clk_wiz_1_100M",
"type": "proc_sys_reset",
"version": "5.0",
}]. Thread: main
14:15:26 DEBUG	: XSCT Command: [hsi::utils::get_supported_os -json /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Thread: main
14:15:26 DEBUG	: XSCT command with result: [hsi::utils::get_supported_os -json /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Result: [null, {"microblaze_0": {"freertos901_xilinx_v1_1": {"name": "freertos901_xilinx",
"version": "1.1",
"desc": "FreeRTOS is a market leading open source RTOS",
"compilerflags": "",
"linkerflags": "-Wl,--start-group,-lxil,-lfreertos,-lgcc,-lc,--end-group",
"repo": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/ThirdParty/bsp/freertos901_xilinx_v1_1",
"standalone_v6_4": {"name": "standalone",
"version": "6.4",
"desc": "Standalone is a simple, low-level software layer. It provides access to basic processor features such as caches, interrupts and exceptions as well as the basic features of a hosted environment, such as standard input and output, profiling, abort and exit.",
"linkerflags": "-Wl,--start-group,-lxil,-lgcc,-lc,--end-group",
"repo": "/opt/Xilinx/SDK/2017.3/data/embeddedsw/lib/bsp/standalone_v6_4",
}]. Thread: main
14:15:26 DEBUG	: XSCT Command: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Thread: main
14:15:26 DEBUG	: XSCT command with result: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Result: [null, ]. Thread: main
14:15:27 DEBUG	: XSCT command with result: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Result: [null, ]. Thread: main
14:15:27 DEBUG	: XSCT Command: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Thread: main
14:15:27 DEBUG	: XSCT Command: [::hsi::utils::get_all_app_details -json], Thread: main
14:15:27 DEBUG	: XSCT command with result: [::hsi::utils::get_all_app_details -json], Result: [null, {"zynq_dram_test": {"userdefname": "Zynq DRAM tests",
"os": "standalone",
"os": "standalone",
"os": "standalone",
"os": "standalone",
"os": "standalone",
"os": "standalone",
"os": "standalone",
"os": "standalone",
"os": "standalone",
"os": "standalone",
"os": "standalone",
"supp_proc": "",
"supp_os": "",
"os": "standalone",
"os": "standalone",
"os": "standalone",
"os": "standalone",
"os": "standalone",
"os": "standalone",
"os": "standalone",
"os": "standalone",
"os": "standalone",
"os": "standalone",
"os": "standalone",
"os": "standalone",
"supp_os": "linux",
"os": "linux",
"supp_os": "linux",
"os": "linux",
}]. Thread: main
14:15:27 DEBUG	: XSCT Command: [::hsi::utils::is_app_supported_on_hw_sw  -hw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf -os standalone -processor microblaze_0 -app hello_world -sw {} -arch {}], Thread: main
14:15:27 DEBUG	: XSCT command with result: [::hsi::utils::is_app_supported_on_hw_sw  -hw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf -os standalone -processor microblaze_0 -app hello_world -sw {} -arch {}], Result: [null, 1]. Thread: main
14:15:29 DEBUG	: XSCT Command: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Thread: main
14:15:29 DEBUG	: XSCT command with result: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Result: [null, ]. Thread: main
14:15:31 DEBUG	: XSCT Command: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Thread: main
14:15:31 DEBUG	: XSCT command with result: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Result: [null, ]. Thread: main
14:15:32 DEBUG	: XSCT Command: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Thread: main
14:15:32 DEBUG	: XSCT command with result: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Result: [null, ]. Thread: main
14:15:33 DEBUG	: XSCT Command: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Thread: main
14:15:33 DEBUG	: XSCT command with result: [::hsi::utils::openhw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf], Result: [null, ]. Thread: main
14:15:39 DEBUG	: Application model: ApplicationModel [projName=Hello_world1, projLoc=/home/jenniffer/plinux/hello_world/hello_world.sdk, hwPlatName=base_mb_wrapper_hw_platform_0, proc=microblaze_0, os=standalone, lang=C, bspName=Hello_world1_bsp, appName=hello_world, newBsp=true, newHw=false, supportedOs={freertos901_xilinx=com.xilinx.sdk.sw.OS@7fdabb3b, standalone=com.xilinx.sdk.sw.OS@7164e28a, linux=com.xilinx.sdk.sw.OS@1b881f1f}, endianness=LITTLE, hwPlatform=com.xilinx.sdk.hw.internal.HwPlatform@51efdb72, appGen=com.xilinx.sdk.appwiz.internal.AppGen@5d01a2eb, extraCompilerFlags=, linuxSysRootPath=null, linuxSysRootPathSelection=false, linuxToolchainSelection=false, linuxToolchainPath=null, petalinuxProjectPath=null, specLocation=null, compilerType=32-bit, elType=N/A, projectBuildType=EXECUTABLE]
14:15:39 DEBUG	: XSCT Command: [::hsi::utils::write_sw_mss -hw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf -sw Hello_world1_bsp -dir /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world1_bsp -processor microblaze_0 -os standalone -app hello_world], Thread: main
14:15:39 DEBUG	: XSCT command with result: [::hsi::utils::write_sw_mss -hw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf -sw Hello_world1_bsp -dir /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world1_bsp -processor microblaze_0 -os standalone -app hello_world], Result: [null, ]. Thread: main
14:15:39 DEBUG	: Proc type microblaze and compiler type 32-bit
14:15:39 DEBUG	: Toolchain type
14:15:39 DEBUG	: Proc ID microblaze for getting proc type from preferences
14:15:39 DEBUG	: Toolchain type is MB for Proc ID microblaze
14:15:39 DEBUG	: ProcType = microblaze, corePrefId = com.xilinx.sdk.appwiz.preference.mb, toolchainPrefId = xilinx
14:15:39 DEBUG	: XSCT Command: [ ::hsi::utils::set_current_hw_sw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world1_bsp/system.mss ], Thread: main
14:15:39 DEBUG	: XSCT command with result: [ ::hsi::utils::set_current_hw_sw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world1_bsp/system.mss ], Result: [null, ]. Thread: main
14:15:39 DEBUG	: XSCT Command: [::hsi::utils::get_hw_sw_details -json /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world1_bsp/system.mss], Thread: main
14:15:39 DEBUG	: XSCT command with result: [::hsi::utils::get_hw_sw_details -json /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world1_bsp/system.mss], Result: [null, {"procname": "microblaze_0",
"osver": "6.4",
}]. Thread: main
14:15:39 DEBUG	: XSCT Command: [::hsi::utils::generate_bsp_sources /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world1_bsp/system.mss /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world1_bsp], Thread: main
14:15:39 DEBUG	: (XSDB Server)/opt/Xilinx/SDK/2017.3/gnu/microblaze/lin
14:15:40 DEBUG	: (XSDB Server)ERROR: ld.so: object '/home/jenniffer/Desktop/usb-driver-HEAD-2d19c7c/libusb-driver.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
14:15:40 ERROR	: (XSDB Server)ERROR: [Hsi 55-1545] Problem running tcl command ::sw_standalone_v6_4::post_generate : ERROR: ld.so: object '/home/jenniffer/Desktop/usb-driver-HEAD-2d19c7c/libusb-driver.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
    while executing
    invoked from within
14:15:40 ERROR	: (XSDB Server)ERROR: [Hsi 55-1450] Error: running generate_bsp.
14:15:40 DEBUG	: XSCT command with result: [::hsi::utils::generate_bsp_sources /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world1_bsp/system.mss /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world1_bsp], Result: [{Format=ERROR: [Common 17-39] 'hsi::generate_bsp' failed due to earlier errors.
, Time=1531426540242, Code=1}, ]. Thread: main
14:15:40 DEBUG	: XSCT Command: [::hsi::utils::closesw /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world1_bsp/system.mss], Thread: main
14:15:40 DEBUG	: XSCT command with result: [::hsi::utils::closesw /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world1_bsp/system.mss], Result: [null, ]. Thread: main
14:15:40 DEBUG	: XSCT Command: [ ::hsi::utils::set_current_hw_sw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world1_bsp/system.mss ], Thread: main
14:15:40 DEBUG	: XSCT command with result: [ ::hsi::utils::set_current_hw_sw /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world1_bsp/system.mss ], Result: [null, ]. Thread: main
14:15:40 DEBUG	: XSCT Command: [::hsi::utils::get_hw_sw_details -json /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world1_bsp/system.mss], Thread: main
14:15:40 DEBUG	: XSCT command with result: [::hsi::utils::get_hw_sw_details -json /home/jenniffer/plinux/hello_world/hello_world.sdk/base_mb_wrapper_hw_platform_0/system.hdf /home/jenniffer/plinux/hello_world/hello_world.sdk/Hello_world1_bsp/system.mss], Result: [null, {"procname": "microblaze_0",
"osver": "6.4",
}]. Thread: main
14:15:40 DEBUG	: Project Hello_world1_bsp to be removed from workspace.
14:15:40 ERROR	: Error generating bsp sources: Failed in generating sources
Visitor estradjm
The libraries are installed and in the most recent versions. Is there anything else that could be causing this issue? Any help is greatly appreciated!
