MicroBlaze Programming Language ???
Hello . . .
Is It possible to program the MicroBlaze soft processor using VHDL rathar than c language ???
because i am familar in VHDL programming , and i am dont know to programming with c .
Thanks . . .
oms
oms,
No. VHDL is used to model and synthesize hardware. MicroBlaze is a 32-bit soft processor that has already been developed. You can program it in C, C++, assembly, or machine code.
You can use VHDL to develop additional peripherals for MicroBlaze.
bt
Dear
thanks for replying
so how can i make the compiler to distinguish between thos languages ,
because when i create a new software application the file exension is .c?
or to write the assembly program by c language?
oms
There are different compilers for the different languages:
mb-gcc for C
mb-g++ for C++
mb-as for assembly (ok, this one is actually an assembler)
The options likely depend on your development flow, as there are multiple possibilities: XPS in GUI mode, XPS in batch mode (e.g. TCL), makefile, SDK, etc.
The XPS GUI gives you the option when you add source to an application of adding a C file (default file type, note the option to change this in the dialog box), C++ source, or other (e.g. .s)
Most users likely use C. It is also possible to in-line assembly into your C file:
http://www.xilinx.com/support/answers/18561.htm (9.2i EDK - How do I include inline assembly within my C source files?)
http://forums.xilinx.com/xlnx/board/message?board.id=Virtex&message.id=1997#M1997 (Microblaze , vertex 4 ML403, Accessing register values from C)
bt
Thanks for replyng me ,
you wrote that The XPS GUI gives you the option when you add source to an application of adding a C file (default file type, note the option to change this in the dialog box), C++ source, or other (e.g. .s)
i want to write my source code using assembly language , Is this possible ? is the file extension (*.s) is used for assembly codes files ? and is
there a need to adjust the compiler (mb-as for assembly ) manually whether in XPS or in SDK ??? if yes , where to do that ?
i want to use assembly because it is familiar to me and i used it before unlike c .
oms
Yes, it should be possible.
Many of the low-level MicroBlaze (and PPC) routines were written in assembly.
For example, see
%XILINX_EDK%\sw\lib\bsp\standalone_v2_00_a\src\microblaze
%XILINX_EDK%\sw\lib\microblaze\src
Yes:
 .S Assembly file, but might have preprocessor directives
 .s Assembly file with no preprocessor directives
per http://www.xilinx.com/support/documentation/sw_manuals/edk10_est_rm.pdf (Embedded System Tools Reference Manual)
I've never used assembly in XPS before.
A quick test shows adding a .s file to a project still uses mb-gcc (accoding to the makefiles automaticcally generated by XPS). I don't necessarily see this as incorrect since mb-gcc obviously can use mb-as. But I'll admit I haven't used assembly here.
It is also possible to script EDK after you use the EDK GUI to create the hardware subsystem.
http://forums.xilinx.com/xlnx/board/message?board.id=EDK&message.id=7063 (Using EDK in batch mode ?)
bt
Can you guide me to any document or anything to use assembly language in microblaze programming like the form of the header and source files , how to make comments , ....etc
i was read the microblaze processor reference gide including chapter 4 (microblaze instruction set arcitecture) , it provides details on instructions but not details but no how to program
oms
If you've already read the MicroBlaze reference guide (which is where I would start), the next step is likely to review the existing assembly files I mentioned above as an example:
You may also find the GNU Assembler documentation useful:
http://sourceware.org/binutils/docs/as/index.html
http://gcc.gnu.org/onlinedocs/gcc-4.3.2/gcc/
http://savannah.nongnu.org/projects/gas-user/
http://www.ibiblio.org/gferg/ldp/GCC-Inline-Assembly-HOWTO.html
bt
Message Edited by timpe on 01-25-2009 10:58 PM
