MicroBlaze is under reset while running sdk
please help me how to fix attached file error
Scholar dpaul24
Re: MicroBlaze is under reset while running sdk
harinatha.reddy@eldaas.com,
Did you try the 3 'Troubleshooting Hints' listed? What are the results?
Please post the BD highliting the system reset input. Re-check on your system_reset signal propagation.
Did you forget to de-assert it?
Has it been connected to the recommended FPGA reset pin (re-check your ucf/xdc)?
FPGA enthusiast!
All PMs will be ignored
Hi harinatha.reddy@eldaas.com ,
How you are providing reset to microblaze? If you are directly providing an external reset from the board please check the polarity.
I also had an experience of getting the same error. That time issue was wrong polarity of reset input to microblaze.
One method I followed is attached.
Reference link : https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug898-vivado-embedded-design.pdf
(page - 110)
Thanks & Regards,
Reshma
Thamk you for your response, i am using xilinx ise 14.7 not vivado tool
If I'm not wrong you might have the same error if the Microblaze is not clocked, so could you provide more details about the clock? If the clock is comming from the PS side (on Zynq based devices) you should ensure that the PS is being initialized prior downloading the application to the memory as otherwise the clock is not going to be running.
Ibai
ok thank you for your suggession i will check
Scholar dpaul24
@ibaie,
The OP is using ISE which mean sthat the FPGA under use is a non-zynq part.
Again, please check your if the clock is provided and the uBlaze is properly brought out of reset. These basic connections have nothing to do with the Xilinx tool type you are using.
FPGA enthusiast!
ok thank you,
i am designing edk design ie, digital input data send to SBC(single board computer) for that i used PCI some cores i have to add can you suggest what i have to add in edk design or any reference designs available share with me
