mestrespartan
MicroC OS-II & microblaze
Does anyone knows how to put the MicroC OS-II in the microblaze? I've followed some notes, that came with the microblaze port, but when i tried to download to the board, it gave an error. I used XMD and did the following:
     "dow executable.elf ( that's what i normally do when i want to put a prog in external memory)"
But this message appeared:
     "Debug operation not supported on the target"
Can anyone help me? tks in advance
Message Edited by mestrespartan on 12-17-2007 05:33 PM
heritage
I just had the same problem.  But this was after I had stepped through a program using the debugger.  I cleaned all software files/libs and rebuilt everything after I restarted edk and it fixed the problem.
Cheers,
Bill Tomb
