Visitor w_d_anderson
Microblaze HWICAP IPROG Code
I am trying to use ICAP which will be controlled by the microblaze to select a complete bitstream to load from flash.  The code (snippet of main code  below) writes the IPROG command to the FIFO to  initialte the warm boot from a new Quad SPI Flash address.  When I do this I see our fpga  not_done LED go off for 15 secs. At this point it loads the wrong image from address 0x0 again.  I don't have the watchdog enabled so I am not sure what causes this timeout.
  I have searched for examples but have not been able to find any with links that are still valid. Any working code snippets appreciated.  BTW, Our project uses a kintex 7.  I am assuming that ICAP can handle quad spi by default.  Also I assume that the bit stream that I load does not need any special ICAP instructions. Are these valid assumptions.
Bill A
--snip--
#define HWICAP_BASEADDR         XPAR_AXI_HWICAP_0_BASEADDR
#define HWICAP_IDCODE_SIZE                  1
#define HWICAP_EXAMPLE_BITSTREAM_LENGTH     8
#define HWICAP_DEVICE_ID XPAR_AXI_HWICAP_0_DEVICE_ID
// Reusing IDCODE array and code to send IPROG
// From UG470 p. 126, Table 7-1
static
u32 ReadId[HWICAP_EXAMPLE_BITSTREAM_LENGTH] =
        0xFFFFFFFF,/* Dummy Word */
        0xAA995566,/* Sync Word*/
        0x20000000,/* Type 1 NO OP */
        0x30020001,/* Write WBSTAR cmd */
        0x00300000,/* Addr in SPI Flash of desired bitstream */
        0x30008001,/* Write CMD */
        0x0000000F,/* Write IPROG */
int  main()
/* SOME GPIO CONTROL CODE DELETED */
* Initialize the HwIcap driver.
ConfigPtr = XHwIcap_LookupConfig(HWICAP_DEVICE_ID);
if (ConfigPtr == NULL) {
return XST_FAILURE;
 Status = XHwIcap_CfgInitialize(&HwIcap, ConfigPtr,ConfigPtr->BaseAddress);
if (Status == XST_SUCCESS) {
    xil_printf("Call XHwIcap_CfgInitialize Success\n\r");
            xil_printf("Attempting Warm Boot\n\r");
         //ret = fpga_iprog(0x0); // IPROG to third image which is in 24 bit address space
         ret = fpga_iprog(0x662000);// IPROG to third image which is in 24 bit address space
          //ret = fpga_iprog(0x1324000); // IPROG to third image which is in 25 bit address space
    xil_printf("\r\n\n fpga_iprog returned %d\n\n\r", ret);  // NEVER SHOULD MAKE IT BACK HERE ALIVE
return 0;
int fpga_iprog(u32 iprog_address)
    u32 Status;
    ReadId[4] = iprog_address;
    Status = HwIcapIPROG(HWICAP_BASEADDR, iprog_address);
    if (Status != XST_SUCCESS) {
        return XST_FAILURE;
   return XST_SUCCESS;
u32 HwIcapIPROG(u32 BaseAddress, u32 iprog_address)
u32 Index;
u32 Retries;
u32 RegData;
             * Write command sequence to the FIFO
for (Index = 0; Index < HWICAP_EXAMPLE_BITSTREAM_LENGTH; Index++) {
                    XHwIcap_WriteReg(BaseAddress, XHI_WF_OFFSET, ReadId[Index]);
             * Start the transfer of the data from the FIFO to the ICAP device.
            XHwIcap_WriteReg(BaseAddress, XHI_CR_OFFSET, XHI_CR_WRITE_MASK);
//<<<< In debugger I get this far which I assumes should cause Warm start??
return XST_SUCCESS;
Re: Microblaze HWICAP IPROG Code
Hi there
I went into exactly same problem as you - did you solve it ?
thanks
