Microblaze MCS debug problem in SDK 2017.3
I have been working on a Microblaze MCS project which started in Vivado/SDK 2017.2 where I was able to build and debug the MCS with no problems at all. I have since moved to Vivado/SDK 2017.3 where the debugging seems not to work at and pushing the debug or run system button in SDK brings up this error message:
I am able to program the FPGA through SDK confirming that the JTAG drivers are working. I have also tried restarting the project from scratch in 2017.3 to rule out any problems in converting projects from one version of Vivado to another.
I am running Vivado on Linux and using an Arty dev board. Attached are the project .hdf and .mmi files
Thanks for your help.
Here's a patch for 2017.3. You can either extract it to $XILINX_SDK, where $XILINX_SDK points to your SDK installation (ex. C:\Xilinx\SDK\2017.3), or extract it to a known location (C:\temp\myvivado) and set the env variable MYVIVADO to point to this directory ($MYVIVADO should have scripts dir from the patch)
Looks like some info is missing from HDF, so there are some internal errors while trying to get the CPU index from HDF. We'll look into this more and provide an update
Thank you for the patch, this has solved the problem.
