Microblaze not going into main function
I have a simple C code which performs addition of 2 numbers. I am using mb-gcc utilitu to generate the elf file and then the data2mem utility to generate the .mem file. I have a firmware which loads the .mem file into the instruction memory of microblaze and then takes the microblaze out of reset. I see that microblaze begins executing and start fetching instructions by adding chipscope on ILMB bus. The problem is it never goes into the main function. Below is my C code .
int main()
{ int i=1,j=2,k;
  k=i+j;
 return 0;
What can be the potential causes of this problem. The same .mem file passes in simulation and microblaze jumps to the address of the main function in a VCS simulation but in silicon it just loops back to address 0x0 and starts exeucting its initialization routines again.
Please note I posted it in another forum but again posting this here because I suspect it might be some toolchain issue.
OK finally solved this problem. Found out the micorblaze was not returning correctly from the unnecessary constructor code.
Forced microblaze to not execute the constructor code by hacing the binary file and now everything works fine.
Basically I guess this is a toolchain related bug which unnecessarily inserts the constructor code in .c files which is not required
