Microblaze on XUPV5-LX110T: Xflow error
Hi everyone,
I'm trying to do some research work involving embedded processor on FPGAs; however, I've been running into a ton of issues just with the initial stages of getting anything to work.
Board: XUPV5-LX110T
Software: ISE 12.2
References: www.xilinx.com/products/boards/xupv5/base-system-builder.htm http://www.xilinx.com/products/boards/xupv5/design_files_122/BSB_CREATE/xupv5-lx110t_bsb_design_creation.pdf
Background: I was originally having issues with constraint errors because I was using the support files from this page http://www.xilinx.com/univ/xupv5-lx110t-bsb.htm, but it turns out that these don't seem to work because I got lots of constraint errors. Lurking around these forums, I found these support files http://www.xilinx.com/products/boards/xupv5/base-system-builder.htm, and these one's actually seem to work (or at least, I'm getting further along in the generate bitstream step from the tutorial above).
However, I'm still having issues. I attached the output from when I try to generate the bitstream to use with SDK. Basically, I get past the majority of placing and routing, and then, I seemingly randomly get the following error with little other information.
All constraints were met.
INFO:Timing:2761 - N/A entries in the Constraints List may indicate that the
constraint is not analyzed due to the following: No paths covered by this
constraint; Other constraints intersect with this constraint; or This
constraint was disabled by a Path Tracing Control. Please run the Timespec
Interaction Report (TSI) via command line (trce tsi) or Timing Analyzer GUI.
Generating Pad Report.
All signals are completely routed.
Total REAL time to PAR completion: 1 mins 55 secs
Total CPU time to PAR completion: 2 mins 1 secs
Peak Memory Usage:  983 MB
Placer: Placement generated during map. Routing: Completed - No errors found. Timing: Completed - No errors found.
Number of error messages: 0 Number of warning messages: 6 Number of info messages: 2
Writing design to file system.ncd
PAR done!
ERROR:Xflow - par: application received signal 11
ERROR:Xflow:42 - Aborting flow execution...
make: *** [__xps/system_routed] Error 1
Done!
I know that the board is a little old, but I'm determined to get this thing working, and your help would be greatly appreciated. If worst comes to worse, I could probably get a different (Virtex-6) board from my professor or change to a different SOC.
I don't think this is a fix for the problem, but it's a workaround. I've seen the same error, but if you look closely at it, it says "PAR done." So, you can issue a command to continu the process, assuming PAR is done.
Looking at the system.make file, I did the following (from implementation directory):
$ bitgen -w -f ../bitgen.ut <name_of_project>
This should get you to the "Bitstream generation is complete." phase.
