01-25-2019 09:37 AM
Trying to upgrade to Vivado 2018.3. I import my SDK projects into my workspace, the projects were previously running under Vivado 2016.4. I get the error "arm-xilinx-linux-gnueabi-gcc" not found in path when I try to build in 2018.3.
According to this link
I need to recreate the projects from scratch and import the sources. Is that correct? I have 15 or so projects that I need to migrate. Is there a way to have the tool do the conversion from 2016.4 to 2018.3? Has anyone else run into this and how did you handle?
01-25-2019 04:00 PM
There are too many differences between 2016.4 and 2018.3 to be able to do a typical project import.
I would recommend these steps:
This will make sure that all the dependencies are accounted for.
Christophe
01-25-2019 04:00 PM
Christophe
10-10-2019 02:15 AM
As per your solution i do all the step and inport the projetc.c file form the sources and run as Lunch on hardware (System debugger) for the project uart_led_zynq.
I am facing following issue.
1. When i type any character in SDK terminal, there is no change in Led display corresponding to the character i type.
2. when i open the block design in Vivado and see in block the uart port i.e uart0 and uart 1 is disbled and only GPIOand I2C 0 and CAN 0 in I/O peripheral is enabled.
kindly suggest me solution to cahnge the LED dispaly from character i type in SDK terminal in SDK 2019.1 version.
