Missing .h files in SDK
I'm using an example project from Xilinx and when I load it into SDK I'm getting compile errors on
several .h files that I'm told are missing but I can see them loaded under .c file tree.  Can anyone tell me how I get SDK to load them properly or what the problem may be?
DeWayne
Message Edited by heedaf on 08-20-2008 02:56 PM
Did you try to build the project in SDK?
Yes it has been built and I'm getting errors like "xemcacif.h:  No such file or directory" and I can see the file loaded.
Try removing and re-adding the files, it sounds like the path is incorrect for this file...
I guess this brings me to the next question, there are around 20-30 missing .h files in the sample file.  Does SDK/EDK track these locations?  I unzipped them to their orignal locations within my own specified folder.  Does the zip file need to be unzipped to specific folder?  EDK seems to be working fine in the current location.
ca you help me to intrgrate a .h file
