ModelSim 6.3a Simulation fails
When I start the Simulation for the EDK9.1 tutorial example I get the following error message
# ** Note: (vsim-3812) Design is being optimized...
# ** Note: (vsim-3865) Due to PLI being present, full design access is being specified.
# Loading c:\Xilinx92i\smartmodel\nt\installed_nt/lib/pcnt.lib/swiftpli_mti.dll
# ** Error: (vsim-3193) Load of "c:\Xilinx92i\smartmodel\nt\installed_nt/lib/pcnt.lib/swiftpli_mti.dll" failed: DLL dependent library not found.
# ** Error: (vsim-PLI-3002) Failed to load PLI object file "c:\Xilinx92i\smartmodel\nt\installed_nt/lib/pcnt.lib/swiftpli_mti.dll".
#         Region: /
# Loading std.standard
# Loading ieee.std_logic_1164(body)
# Loading ieee.std_logic_arith(body)
# Loading ieee.std_logic_unsigned(body)
# Loading ieee.numeric_std(body)
# Loading unisim.vcomponents
# Loading std.textio(body)
# Loading ieee.vital_timing(body)
# Loading ieee.vital_primitives(body)
# Loading unisim.vpkg(body)
# Loading work.testbench_vhd_conf#1
# Error loading design
# Error: Error loading design
#        Pausing macro execution
# MACRO ./testbench_vhd.fdo PAUSED at line 11
Message Edited by mcsqr50 on 11-19-2008 07:14 PM
