Mentor
Mentor
Modelsim simulation problem
Hi all,
I have a custom board -XC3S700A FPGA- with lots of peripherals and memories like parallel SRAM.
I have developped a simple EDK application to test my memory - I've connected the Async memory to Microblaze using xps_mch_emc.
I print 'X' character at the end of writing loop and 'E' whenever I read a wrong value - which you see my simple code below.
I see the 'X' and 'E' characters but I don't see controlling signals of memory -Address, data,...- in simulation?!.
I would appreciate any help on this issue. I should add that I am using XIo_Out32 and XIo_In8 memory write and read operations.
#define			High_Address_Limit		0xFF
#define			Write_SRAM				XIo_Out32
#define			Read_SRAM				XIo_In8
int main (void) {
   #if XPAR_MICROBLAZE_0_USE_ICACHE
      Xil_ICacheInvalidate();
      Xil_ICacheEnable();
   #endif
   #if XPAR_MICROBLAZE_0_USE_DCACHE
      Xil_DCacheInvalidate();
       Xil_DCacheEnable();
   #endif
Xuint32 i;
Xuint32 Address;
	i = 0;
	for (Address=0x00;Address <= (High_Address_Limit);Address++)
		Write_SRAM((Xuint32*)Address,i);
		i++;
		if (i==0xff)
			print("X");
	i = 0;
		if ((Read_SRAM((Xuint32*)Address) & 0xFF)!= i)
			print("E");
		i++;
while(1);
      Xil_DCacheDisable();
   #endif
      Xil_ICacheDisable();
   #endif
   return 0;
Thanks in advance,
Hossein
Hossein
Mentor
Mentor
Re: Modelsim simulation problem
Yes, in the write cycle I used a file and wrote the numbers in it. Then I read that file and put it on MEM_DQ in the read cycle.
The problem was really related to wrong Address range I had used in my code?!..
I have used EMC address in the 0x80180000-0x801fffff range, while you see I was addressing elsewhere!. Very funny?!.. Isn't it?!..
I saw all controlling signals after adding the base_address to the write and read functions.
Thank you for your attention.
Hossein
Hossein
Do you have memory model of SRAM included as a part of testbench?
--HS
Mentor
Mentor
Hossein
Hossein
