Visitor chrisab508
Modifications to NPI Example Interface
Hello Everyone,
I'm having trouble understanding how I would modify the code from AR#24912 to suit my needs.  I'm writing to DDR (not reading), and I'm doing single writes at a time (no burst).  So the way I see it, I need three signals to modify: data, address, and write_enable.  Looking at the example from AR#24912 we have the following VHDL which will write all zeros to memory address zero:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity my_npi is
  generic(
    C_PI_ADDR_WIDTH       :     integer                                          := 32;
    C_PI_DATA_WIDTH       :     integer                                          := 64;
    C_PI_BE_WIDTH         :     integer                                          := 8;
    C_PI_RDWDADDR_WIDTH   :     integer                                          := 4
  port(
    -- User interface signals
    Compare_Error         : out std_logic                                        := '0';
    -- MPMC Port Interface - Bus is prefixed with NPI_
    XIL_NPI_Addr              : out std_logic_vector(C_PI_ADDR_WIDTH-1 downto 0)     := (others => '0');
    XIL_NPI_AddrReq           : out std_logic                                        := '0';
    XIL_NPI_AddrAck           : in  std_logic                                        := '0';
    XIL_NPI_RNW               : out std_logic                                        := '0';
    XIL_NPI_Size              : out std_logic_vector(3 downto 0)                     := (others => '0');
    XIL_NPI_WrFIFO_Data       : out std_logic_vector(C_PI_DATA_WIDTH-1 downto 0)     := (others => '0');
    XIL_NPI_WrFIFO_BE         : out std_logic_vector(C_PI_BE_WIDTH-1 downto 0)       := (others => '0');
    XIL_NPI_WrFIFO_Push       : out std_logic                                        := '0';
    XIL_NPI_RdFIFO_Data       : in  std_logic_vector(C_PI_DATA_WIDTH-1 downto 0)     := (others => '0');
    XIL_NPI_RdFIFO_Pop        : out std_logic                                        := '0';
    XIL_NPI_RdFIFO_RdWdAddr   : in  std_logic_vector(C_PI_RDWDADDR_WIDTH-1 downto 0) := (others => '0');
    XIL_NPI_WrFIFO_Empty      : in  std_logic                                        := '0';
    XIL_NPI_WrFIFO_AlmostFull : in  std_logic                                        := '0';
    XIL_NPI_WrFIFO_Flush      : out std_logic                                        := '0';
    XIL_NPI_RdFIFO_Empty      : in  std_logic                                        := '0';
    XIL_NPI_RdFIFO_Flush      : out std_logic                                        := '0';
    XIL_NPI_RdFIFO_Latency    : in  std_logic_vector(1 downto 0)                     := (others => '0');
    XIL_NPI_RdModWr           : out std_logic                                        := '0';
    XIL_NPI_InitDone          : in  std_logic                                        := '0';
    XIL_NPI_Clk               : in  std_logic                                        := '0';
    XIL_NPI_Rst               : in  std_logic                                        := '0'
end entity;
architecture arc_my_npi of my_npi is
  type state_type is (RST, IDLE, TX_DATA, TX_ADDR, RX_ADDR, RX_WAIT_NOT_EMPTY,
                      RX_WAIT_RXFIFO_LAT2, RX_WAIT_RXFIFO_LAT1, RX_POP);
  signal npi_cs, npi_ns    : state_type;
  signal gen_data          : std_logic                                    := '0';
  signal npi_wrfifo_push_i : std_logic                                    := '0';
  signal npi_req_set       : std_logic                                    := '0';
  signal npi_rnw_i         : std_logic                                    := '0';
  signal npi_wrfifo_be_i   : std_logic_vector(C_PI_BE_WIDTH-1 downto 0)   := (others => '0');
  signal data              : std_logic_vector(C_PI_DATA_WIDTH-1 downto 0) := (others => '0');
  signal npi_size_i        : std_logic_vector(3 downto 0)                 := (others => '0');
  signal npi_addrreq_int   : std_logic                                    := '0';
  signal initdone          : std_logic                                    := '0';
  signal compare_enable    : std_logic                                    := '0';
  signal npi_rdfifo_pop_i  : std_logic                                    := '0';
  signal compare_error_i   : std_logic                                    := '0';
begin
  -- Internally used outputs
  XIL_NPI_RdFIFO_Pop <= npi_rdfifo_pop_i;
  -- Basic pipeline for write path signals
  PIPE         : process (XIL_NPI_Clk)
  begin
    if rising_edge(XIL_NPI_Clk) then
      initdone        <= XIL_NPI_InitDone;
      XIL_NPI_WrFIFO_Push <= npi_wrfifo_push_i;
      XIL_NPI_WrFIFO_BE   <= npi_wrfifo_be_i;
      XIL_NPI_WrFIFO_Data <= data;
    end if;
  end process;
  -- Upon address ack, clear address qualifiers
  ADDRACK_PIPE : process (XIL_NPI_Clk, XIL_NPI_AddrAck)
  begin
      if XIL_NPI_AddrAck = '1' then
        XIL_NPI_RNW       <= '0';
        XIL_NPI_Size      <= "0000";
      else
        XIL_NPI_RNW       <= npi_rnw_i;
        XIL_NPI_Size      <= npi_size_i;
      end if;
    end if;
  end process;
  -- Address ack pipeline
  -- Deassert address request
  NPI_REQ_PIPE : process (XIL_NPI_Clk, XIL_NPI_AddrAck, npi_req_set)
  begin
        npi_addrreq_int <= '0';
      elsif npi_req_set = '1' then
        npi_addrreq_int <= '1';
      else
        npi_addrreq_int <= npi_addrreq_int;
      end if;
    end if;
  end process;
  XIL_NPI_AddrReq           <= npi_addrreq_int;
  -- Data testbench generator
  -- a simple counter for each NPI beat
  -- activated for both writes and reads (to verify returned data)
  DATA_GEN : process (XIL_NPI_Clk, XIL_NPI_Rst, gen_data)
  begin  -- process
      if XIL_NPI_Rst = '1' then
        data <= (others => '0');
      elsif (gen_data = '1' or compare_enable = '1') then
        data <= data + 1;
      else
      end if;
    end if;
  end process;
  -- Testbench compare logic
  COMPARE : process (XIL_NPI_Clk, XIL_NPI_Rst, compare_enable, XIL_NPI_RdFIFO_Data, data)
  begin  -- process
        compare_error_i <= '0';
      elsif (compare_enable = '1') and (XIL_NPI_RdFIFO_Data /= data) then
        -- If data does not match during a valid read, set error flag
        compare_error_i <= '1';
      else
        compare_error_i <= compare_error_i;
      end if;
    end if;
  end process;
  Compare_Error <= compare_error_i;
  -- State machine to sequence through NPI transactions
  -- It will perform a cacheline write to address 0 and then perform a
  -- cacheline read to the same address
  -- Typically, this would be broken into separate read and write processes
  -- with some local arbitration for the NPI address request, and each read
  -- and write FIFOs operating independently of each other
  NPI_STATE_NS : process (npi_cs, data, XIL_NPI_AddrAck, XIL_NPI_RdFIFO_Latency, XIL_NPI_RdFIFO_Empty)
  begin
    --default signal values if not overriden by current state
    npi_ns                  <= npi_cs;
    gen_data                <= '0';
    npi_wrfifo_push_i       <= '0';
    npi_req_set             <= '0';
    npi_rnw_i               <= '0';
    npi_size_i              <= "0000";
    npi_wrfifo_be_i         <= "00000000";
    case (npi_cs) is
      when RST     =>
        npi_ns              <= IDLE;
      when IDLE    =>
        -- Start pushing data into write FIFO
        npi_ns              <= TX_DATA;
        gen_data            <= '1';
        npi_wrfifo_push_i   <= '1';
        npi_wrfifo_be_i     <= "11111111";
      when TX_DATA =>
        -- Continue to fill write FIFO until entire burst is in FIFO
        -- This is conservative, a more agressive approach is to rate-
        -- match with memory single data rate relative to NPI rate enough
        -- to prevent underflow of write FIFO
        if (data = "0100") then
          gen_data          <= '0';
          -- Start address phase
          npi_ns      <= TX_ADDR;
          npi_req_set <= '1';
          npi_rnw_i   <= '0';
          npi_size_i  <= "0010";
        else
          -- Continue to push data into WrFIFO
          npi_ns             <= TX_DATA;
          gen_data           <= '1';
        end if;
      when TX_ADDR             =>
        -- Hold qualifiers active  until transaction accepted
        -- into MPMC control path
          -- Start read, which starts with the address phase first
          npi_ns             <= RX_ADDR;
          npi_req_set        <= '1';
          npi_rnw_i          <= '1';
        else
          npi_ns             <= TX_ADDR;
          npi_req_set        <= '1';
          npi_rnw_i          <= '0';
        end if;
      when RX_ADDR             =>
          -- Assuming at least one cycle DDR turnaround latency
          -- to simplify logic
          -- Then wait until FIFO reports that it is non-empty
          npi_ns             <= RX_WAIT_NOT_EMPTY;
          npi_req_set        <= '0';
          npi_rnw_i          <= '0';
        else
          npi_ns             <= RX_ADDR;
          npi_req_set        <= '1';
          npi_rnw_i          <= '1';
        end if;
      when RX_WAIT_NOT_EMPTY   =>
        -- Depending on Rd_FIFO_Latency, wait before popping read FIFO
        if XIL_NPI_RdFIFO_Empty = '0' then
          if XIL_NPI_RdFIFO_Latency = "10" then
            npi_ns           <= RX_WAIT_RXFIFO_LAT2;
            npi_rdfifo_pop_i   <= '1';
          elsif XIL_NPI_RdFIFO_Latency = "01" then
            npi_ns           <= RX_WAIT_RXFIFO_LAT1;
          else
            -- Data can be popped now, start compare logic
            npi_ns           <= RX_POP;
            compare_enable   <= '1';
          end if;
        else
        end if;
      when RX_WAIT_RXFIFO_LAT2 =>
        -- First wait state for Latency = 2
        if XIL_NPI_RdFIFO_Empty = '1' then
        else
        end if;
      when RX_WAIT_RXFIFO_LAT1 =>
        -- Second wait state for Latency = 2
        -- First wait state for Latency = 1
        else
          npi_ns             <= RX_POP;
        end if;
      when RX_POP              =>
        -- Continue to pop data until read FIFO empty
          npi_ns             <= RX_POP;
        else
          -- Start over with another write/read
          npi_ns             <= IDLE;
          npi_rdfifo_pop_i   <= '0';
          compare_enable     <= '0';
        end if;
    end case;
  end process;
  -- State machine synchronous logic
  NPI_STATE_SYNC : process (XIL_NPI_Clk, XIL_NPI_Rst, initdone)
  begin
      if ((XIL_NPI_Rst = '1') or (initdone = '0')) then
        npi_cs <= RST;
      else
        npi_cs <= npi_ns;
      end if;
    end if;
  end process;
end arc_my_npi;
What would I need to modify here to write specific data to a specific address? It looks like I would need to place my data on the "XIL_NPI_WrFIFO_Data" vector (looks like signal data also), and my address onto the XIL_NPI_Addr vector, but where should the write_enable signal go?
I would appreciate any help people could offer.
Thank you,
Chris
