Moving from standalone to xilkernel
I was looking for some guide or tutorial as to how to use the xil drivers from xilkernel.
It seems that they are more described from standalone.
What I am missing is some guidance as to how these APIs need to be called from xilkernel.
For example, the UART interrupt APIs,
1. Is the API re-entrable ?
2.Is the API thread-safe ?
It  seems that such information is very relevant for xilkernel applications.
Are there any examples available ?
Thank you,
Ran
Re: Moving from standalone to xilkernel
hi,
a better starting point for looking at xilkernel is to refer example design available at http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_4/ug758.pdf
--hem
Hi Hem,
Thanks for that link. It is important starting point.
Still, I'm not sure about the issue of thread safety and reentrance of the xilinx HW driver APIs (uart, spi, gpio, i2c, etc.) .
For example, all the XUART APIs and XGPIO APIs, Do you think they can they be called from multtiple threads ?
Thank you,
Ran
Scholar sampatd
From UG646:
"Xilkernel, by definition, creates a multi-threaded environment. Many library and driver routines
might not be written in a thread-safe or re-entrant manner. Examples include the C library
routines such as printf( ), sprintf( ), malloc( ), free( ). When using any library
or driver API that is not a part of Xilkernel, you must make sure to review thread-safety and reentrancy
features of the routine. One common way to prevent incorrect behavior with unsafe
routines is to protect entry into the routine with locks or semaphores."
Thank you,
I meant in my question Xil-drivers APIs (not malloc) such as:
XUartNs550_Recv
XUartNs550_Send
ReceiveDataHandler -> calls also _UserRcvIntHandler
SendDataHandler  -> calls also _UserSendIntHandler
XGPIO APIs, and many more...
Note that the question of concurrency is relevant not only for OS with thread capability, but also in standalone platform:
If we send/recv at the same time from several ports, we get that these APIs: ReceiveDataHandler , SendDataHandler   can be called in concurrency. It means, as far as I understand, that both of this APIs need to be re-entrent, i.e. if any of the following use globals we can fail: ReceiveDataHandler , _UserRcvIntHandler, SendDataHandler  , _UserSendIntHandler.
I'll be happy to have any comments or feedback on this issue.
Ran
