Multiple ultra96 boards not recognised by Xilinx SDK 2019.1
I'm trying to debug multiple Ultra96 boards via the Xilinx System Debugger. I'm trying to use the PS of the two boards to run different programs.
However, when I connect both devices to my machine, only one device is shown in the list of targets. How do I get it to show the other target as well? Has anyone encountered the same issue?
Re: Multiple ultra96 boards not recognised by Xilinx SDK 2019.1
Hello @hi116
Can you see the your multi targets in "Targets Connection View"?
Please refer Using Xilinx SDK.
Thank you
Ka2ki
Hi there,
I have tried that but only one board is shown. I'm using windows, so when I select device manager, I can see that the two boards are connected to two different serial ports.
Found a link describing the same problem that I'm encountering
http://zedboard.org/content/multiple-jtaguart-pods
