legendbb
Voyager
Voyager
My Win10 SDK compile is 10x slower than Ubuntu
Didn't notice as much a difference when I was on Win7.
Any insight on how to speed up Win10 compile?
Tags (4)
austin
Check you do not have a virus,
Check what else is running.
Sounds like a typical windoze machine issue.....
Austin Lesea
Principal Engineer
Xilinx San Jose
austin
Austin Lesea
Principal Engineer
Xilinx San Jose
jeff.luminartech
I solved this problem by excluding the Vivado and SDK installation folder from Windows Defender.
  • Open Windows Defender Security Center
  • Click on Virus & threat protection
  • Click on Virus & threat protection settings
  • Scroll down to Exclusions, click Add or remove exclusions
  • Add folder:  C:\Path\To\Xilinx\Installation
This cut the time to build a basic BSP down from 114 seconds to 23 seconds...much closer to the times we see on Ubuntu!
amucha
Hello @legendbb,
you tagged @austin's reply as solution, could you maybe give a hint as to what was the actual cause, respectively solution in your case?
Thanks!
We're discussing the same problem (on Windows 7 x64) in this thread:
https://forums.xilinx.com/t5/Embedded-Development-Tools/SDK-very-slow-while-building-project/td-p/855090
