luis7fernando
Need help to make a Read No ACK on ICC
I am using the xilinx IIC core on a Spartan 3E Starter board. I can write fine using the examples given by xilinx but I could not read a register from an IIC device that requires a read without ACK. Can anybody help me please ? Thanks in advance.
eteam00
Instructor
Instructor
This means that all IIC slave devices signal ACK both
  • after receiving the WRITE command
  • after receiving WRITE_DATA
Yes?
Just to be clear...  Which are you saying:
  • The slave device will not continue a READ operation once the master signals an ACK?
  • The slave device will not signal an ACK (which means it is signaling NACK) after receiving the READ command from the master?
  • Something else?
A look at the device datasheet might be helpful.  Is the device in question one of the standard IIC devices on the Spartan-3e Starter board?
-- Bob Elkind
SIGNATURE:
Summary:
