Need to set compiler option -ftemplate-backtrace-limit=0 in SDK 2018.2.2
I just upgraded a project from SDK2017.2 to SDK 2018.2.2.   In doing so I'm receiving the following error which is just a warning.
  [ skipping x instantiation contexts, use -ftemplate-backtrace-limit=0 to disable ]
How can I set this compiler option in SDK?   I've looked project properties, C/C++ Build -> Seetings -> Tool Settings but I can't seem to find an option that fits.
Does anyone have an idea on how to set this compiler switch?
Please try specifying the option in C/C++ Build Settings as shown in the following screenshot
Raju
Raju
Worked like a champ. Thanks for the assistance.
