Nested TCL scripts
I would like to call a TCL script from within a TCL script.  Not sure if Vivado supports this.  If not, am I stuck splitting my overall TCL command sequences between multiple TCL scripts and calling them all from a single vivado command like this:
vivado -mode batch -source init.tcl build.tcl sim.tcl
Guide
Guide
Re: Nested TCL scripts
A Tcl script can be invoked from inside another Tcl script (or from the command line) using the Tcl command "source".
source <tcl_script>
This will transfer control to the <tcl script> execute the commands there until they complete, and then return control bacl to the script (or command line) that executed the "source" command.
Avrum
https://www.tcl.tk/man/tcl8.5/tutorial/Tcl26.html
Mentor
Mentor
Hi @corydearing
Try the following.
1. Create the following file as main tcl file.
source init.tcl
source build.tcl
source sim.tcl
2. Run the following command to launch vivado.
vivado -mode batch -source main.tcl
Guide
Guide
source <tcl_script>
Avrum
oops, your right, my link was for external exe files . !!
teach me to not read when Im tired,
