Number of cycles required to transfer data between 32-bit microblaze and custom IP in artix7
I have created a custom IP using Xilinx Vivado with Artix-7 FPGA. The AXI bus is used in between the 32-bit Microblaze and custom IP. I need to send the inputs to the custom IP from the Microblaze via 32-bit AXI bus. Similarly, the data output from the custom IP needs to be transferred to the Microblaze via 32-bit AXI bus. What would be the number of cycles required to transfer data between 32-bit microblaze and custom IP in artix7 fpga?
smarell
Community Manager
Community Manager
If it a 32-bit to 32-bit, it requires just one cycle.
Thanks for your reply. Is there any reference document for this?
smarell
Community Manager
Community Manager
We don't have a reference document for this but you can validate in simulation with a simple test case.
