OCM addresses in lscript.ld
In UG585, it states Zynq-7000 has 256K OCM. Upon entering the user mode, the RAM is located at 0x0000_0000 to 0x0002_FFFF and FFFF_0000 - FFFF_FFFF. But my generated project shows:
The total OCM is less than 256K, what is the other bytes preserved for?
Re: OCM addresses in lscript.ld
That space is used to "park" Core 1. There is code that keeps Core 1 in WFE state in case it wakes up before an OS has a chance to load some code for it.
Christophe
Christophe
Scholar ericv
@diverger
You may want to change the script to declare 256K in the OCM instead of 64K as it is in yours:
ps7_ram_1    0xFFFC0000   0x3FE00
And yes, the upper 256 bytes shouldn't be touched as @cch indicated, as they are used during boot-up... unless this area is tagged as NOLOAD.
